I have an Intel 82579LM gigabit card but I can´t get it to its default settings, can you help me?
The driver version is 11.15.16.0
I do not have Intel PROset installed
Hi RescateHistoricoNetworks,
Thank you for contacting Intel.
Please go into Intel® 82579LM Adapter Properties in Device Manager, see if you have the "Use Default" option.
You may refer to our website below:
http://www.intel.com/support/network/sb/cs-025841.htm Network Connectivity — Advanced Settings for Intel® Ethernet 10/100 and Gigabit Adapters
In case you don't have this option, you may try to uninstall/reinstall your network adapter.
Please feel free to contact us again if you need further assistance.
Sincerely,
Sandy
It does not have or show "Use Default". I do not have Intel PROset installed, so it doesn´t show it to me. The problem is that I used to have good connectivity within my network which included to other work stations and a NAS, we are connected through a switcher, lately I included a Mac computer, I was having difficulties transferring info between the Mac and a computer so a mess with its properties hoping I would get a better rate between the two but when I changed the properties it also harm the connectivity with the other two work stations but the NAS. So, I want to get the properties back to normal. Can you help me?
I seriously don´t feel like your helping much....Everybody tells me that you are the one that can help me but you´re not, I´m sorry for any inconvinience... thanx for all... I´ll look some place else.....
Sorry for the late reply.
Can you provide your motherboard or system model so I can try to find the right driver for your network connection?
Please indicate your Windows* version too. Thanks.
I suggest to install PROSet Software so you'll have the "Use Default" option.
Sincerely,
Sandy
I appreciate your assistance. I looked in the Intel website and found a driver PROwin64 which said it was for windows 7 x64.
OS NameMicrosoft Windows 7 ProfessionalVersion6.1.7600 Build 7600Other OS DescriptionNot AvailableOS ManufacturerMicrosoft CorporationSystem NameMETUSSystem ManufacturerHewlett-PackardSystem ModelHP Z820 WorkstationSystem Typex64-based PCProcessorIntel(R) Xeon(R) CPU E5-2650 0 @ 2.00GHz, 2001 Mhz, 8 Core(s), 16 Logical Processor(s)BIOS Version/DateHewlett-Packard J63 v02.08, 17/10/2012SMBIOS Version2.7Windows DirectoryC:\WindowsSystem DirectoryC:\Windows\system32Boot Device\Device\HarddiskVolume4LocaleMÈxicoHardware Abstraction LayerVersion = "6.1.7600.16385"User NameMETUS\AdministratorTime ZoneCentral Daylight Time (Mexico)Installed Physical Memory (RAM)8.00 GBTotal Physical Memory7.92 GBAvailable Physical Memory5.67 GBTotal Virtual Memory15.8 GBAvailable Virtual Memory12.9 GBPage File Space7.92 GBPage FileC:\pagefile.sysHere is all the information I gathered by running diagnostic tests.
Info Driver
12.10.29.0 built by: WinDDK
Driver Date: 02/05/2014
Intel PROSet Version 20.0.10.0
Speed: 1.00 Gbps/Full Duplex
Diagnostics
Run Test
Connection Status : Failed
This test relies on a response from a
gateway, DNS, DHCP, or WINS server and
no such response was received. Any such
server for this connection may be unavailable
or misconfigured.
This adapter is configured
to obtain an IP address automatically
but no DHCP server is present on the network.
Windows selected an IP address using Alternate
Private IP Addressing.
Cable Link Status : Passed
This adapter is running at full speed.
Run Test: Cable
Cable Length Status :PassedCable Length:6 meters
Cable polarity Status :Passed
Cable polarity normal.
Local Receiver Status :Passed
Remote Receiver Status :Passed
Cable Quality Status :Passed
Cable quality is excellent.
Cable Integrity Status :Passed
No cable problems detected.
Run Test: Hardware
Register Status: PassedEEPROM Status : PassedFIFO Status : Passed
Interrupt Status : Passed
Loopback Test(s) : Passed
Dear RescateHistoricoNetworks,
Thank you for providing your system information.
You may refer to our website for the default values of advanced settings:
http://www.intel.com/support/network/adapter/pro100/sb/CS-029402.htm http://www.intel.com/support/network/adapter/pro100/sb/CS-029402.htm
In case you still encounter poor connectivity, here are the settings you can try under Performance Options:
1. Interrupt Moderation Rate - OFF
2. Increase Receive Buffers - Default 512 / Range 128 - 2048 in increments of 64
3. Increase Transmit Buffers - Default 512 / Range 128 - 16384 in increments of 64
For Receive and Transmit Buffers, you may set it to 1024 or max at 2048
Info Driver
- I noticed you have updated the network adapter driver from the previous version 11.15.16.0 and have PROSet installed.
- If you continue to experience poor connection, please re-install the customized driver provided by HP -
http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=5225042&swLangOid=8&swEnvOid=4061 http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=5225042&swLangOid=8&swEnvOid=4061
***This link will take you off of the Intel website. Intel does not control the content of the destination website.
Click on Driver - Network
Click on "Intel PRO/1000 Drivers release 19 (Win.7-64) (International)" to download.
Hope this helps improve your system's connectivity. We look forward to your test results.
Sincerely,
Sandy
I do not get the option you mentioned
These are the options I get, could you tell me which one to used
DescripciónVersión actualTamaño (MB)Versión anteriorDescargarhttp://h20564.www2.hp.com/hpsc/swd/public/detail?sp4ts.oid=5225042&swItemId=wk_144090_1&swEnvOid=406... Controlador de Broadcom NetXtreme Gigabit para Microsoft Windows 7 y Windows Vista (64 bits) (Latin American) http://www.hp.com/go/ssm 16.8.4.1 A14 ene 2015185.9http://h20564.www2.hp.com/hpsc/swd/public/detail?sp4ts.oid=5225042&swItemId=wk_106070_1&swEnvOid=406... 14.2.0.5 Rev. A
15 abr 2014http://h20564.www2.hp.com/hpsc/swd/public/detail?sp4ts.oid=5225042&swItemId=wk_131702_1&swEnvOid=406... Controlador de LAN inalámbrica Intel para Microsoft Windows 7 http://www.hp.com/go/ssm 16.8.0.6 Rev. A
1 may 2014280.3 http://h20564.www2.hp.com/hpsc/swd/public/detail?sp4ts.oid=5225042&swItemId=wk_122900_1&swEnvOid=406... Controladores Intel PRO/1000 versión 18 para Microsoft Windows 7 (64 bits) (Latin American) http://www.hp.com/go/ssm R18_308003 Rev. A
9 ene 201437 </t...
i uninstall the driver and Install this one http://h20564.www2.hp.com/hpsc/swd/public/detail?sp4ts.oid=5225042&swItemId=wk_123527_1&swEnvOid=406... Controladores Intel PRO/1000 versión 18 para Microsoft Windows 7 (64 bits) (Latin American but it isnt helping... the speed is worst... help please!!! I tried to change all that you mention but it didn`t help.
2. Increase Receive Buffers -2048
3. Increase Transmit Buffers -2048
Thanks for getting back to us with your test results.
Other Advance Options you can try is to disable:
1. Jumbo Packet
2. Large Send Offload (IPv4) and (IPv6)
3. Offload TCP Segmentation
4. TCP Checksum Offload (IPv4) and (IPv6)
5. UDP Checksum Offload (IPv4) and (IPv6)
These advanced settings are listed on the website below:
http://www.intel.com/support/network/adapter/pro100/sb/CS-029402.htm Intel® Server Adapters — Advanced Driver Settings for Intel® Ethernet 10 Gigabit Server Adapters
Hope this is helpful.
Sincerely,
Sandy
Hello Sandy,
your recommendations helped me solve the speed transfer between my pc´s but the problem now is a Mac that I have in the same network. It does not allow me to r/w at the same time. in addition, the speed is too slow and that hurts the pc´s connected to the network. I ping form a pc to the mac and it shows interruptions but when I ping from the Mac to the pc´s it shows that they have good communication... what would you say is the problem?
you can try to match the settings of your mac to the ones set on pc's and check if this would help.
regards,
Vince
