Ethernet Products
5742 Discussions
Intel 82579LM NIC driver memory leak in HCK for Windows 8.1
MHo10
Hi I've got a motherboard with the Intel 82579LM NIC adapter and trying to do the HCK test for it. However it encountered the issues during the "System - Sleep and PNP (disable and enable) with IO before and after", and a bugcheck was thrown. I've installed the Windows debugger and trace the memory dump file, and noticed there's memory leak on the NIC driver, for both inbox and the latest network driver in the 18.7 driver pack.
So is that there's the bug in the driver file, or the NIC itself got the issue so I need another one to do the same test?
Here's the bugcheck analysis for the inbox Windows 8.1 driver (e1i63x64.sys):
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck C4, {62, ffffe00001d0bae0, ffffe000039f5a30, 1}
Probably caused by : e1i63x64.sys
Followup: MachineOwner
7: kd> !analyze -v
DRIVER_VERIFIER_DETECTED_VIOLATION (c4)
A device driver attempting to corrupt the system has been caught. This is
because the driver was specified in the registry as being suspect (by the
administrator) and the kernel has enabled substantial checking of this driver.
If the driver attempts to corrupt the system, bugchecks 0xC4, 0xC1 and 0xA will
be among the most commonly seen crashes.
Arguments:
Arg1: 0000000000000062, A driver has forgotten to free its pool allocations prior to unloading.
Arg2: ffffe00001d0bae0, name of the driver having the issue.
Arg3: ffffe000039f5a30, verifier internal structure with driver information.
Arg4: 0000000000000001, total # of (paged+nonpaged) allocations that weren't freed.
Type !verifier 3 drivername.sys for info on the allocations
that were leaked that caused the bugcheck.
Debugging Details:
BUGCHECK_STR: 0xc4_62
IMAGE_NAME: e1i63x64.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 51496739
MODULE_NAME: e1i63x64
FAULTING_MODULE: fffff80002974000 e1i63x64
VERIFIER_DRIVER_ENTRY: dt nt!_MI_VERIFIER_DRIVER_ENTRY ffffe000039f5a30
Symbol nt!_MI_VERIFIER_DRIVER_ENTRY not found.
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 2
ANALYSIS_VERSION: 6.3.9600.16384 (debuggers(dbg).130821-1623) amd64fre
LAST_CONTROL_TRANSFER: from fffff801c28e66a8 to fffff801c23c70a0
STACK_TEXT:
ffffd000`20c8d488 fffff801`c28e66a8 : 00000000`000000c4 00000000`00000062 ffffe000`01d0bae0 ffffe000`039f5a30 : nt!KeBugCheckEx
ffffd000`20c8d490 fffff801`c28eac4a : fffff800`02974000 ffffe000`01d0ba20 00000000`00000016 00000000`ffffffff : nt!VerifierBugCheckIfAppropriate+0x3c
ffffd000`20c8d4d0 fffff801`c24232e8 : 00000000`00000000 00000000`00001000 0000007f`00000001 ffffe000`0139a690 : nt!VfPoolCheckForLeaks+0x4a
ffffd000`20c8d510 fffff801`c28d8060 : fffff801`c2523cc0 fffff801`c2523cc0 ffffe000`01d0ba20 00000000`00000002 : nt! ?? ::FNODOBFM::`string'+0x4bd58
ffffd000`20c8d5a0 fffff801`c274b6c6 : 00000000`00000000 ffffe000`01d0ba20 ffffc000`02be8b40 ffffe000`016027e0 : nt!VfDriverUnloadImage+0x34
ffffd000`20c8d5d0 fffff801`c274b630 : 00000000`00000000 ffffe000`01d0ba20 ffffe000`016027e0 ffffe000`016027e0 : nt!MiUnloadSystemImage+0x7e
ffffd000`20c8d650 fffff801`c274b578 : 00000000`00000000 ffffe000`00144420 ffffe000`016027e0 00000000`76697244 : nt!MmUnloadSystemImage+0x20
ffffd000`20c8d680 fffff801`c2628f28 : 00000000`00000000 ffffe000`016027e0 ffffe000`00144420 ffffe000`01c78050 : nt!IopDeleteDriver+0x40
ffffd000`20c8d6c0 fffff801`c22df05f : 00000000`00000000 ffffe000`01c78050 ffffe000`016027e0 ffffe000`01c78020 : nt!ObpRemoveObjectRoutine+0x64
ffffd000`20c8d720 fffff801`c268c79f : ffffe000`01c78050 ffffe000`00144580 ffffd000`20c8d650 ffffe000`00000004 : nt!ObfDereferenceObject+0x8f
ffffd000`20c8d760 fffff801`c2628f28 : ffffcf80`14ba4fd0 00000000`00000024 ffffe000`011e8880 ffffe000`019c6880 : nt!IopDeleteDevice+0x47
ffffd000`20c8d790 fffff801`c22df05f : 00000000`00000000 00000000`00000000 ffffe000`01c78050 ffffe000`019c6870 : nt!ObpRemoveObjectRoutine+0x64
ffffd000`20c8d7f0 fffff801`c232d705 : ffffe000`011ef490 ffffe000`012222d0 00000000`00000000 ffffffff`80000a30 : nt!ObfDereferenceObject+0x8f
ffffd000`20c8d830 fffff801`c26956b1 : ffffe000`011e8880 ffffe000`011ef490 ffffc000`005a29a0 ffffe000`011e8880 : nt!PnpRemoveLockedDeviceNode+0x245
ffffd000`20c8d890 fffff801`c269562a : 00000000`00000000 ffffc000`005a29a0 ffffe000`011ef490 00000000`3f051397 : nt!PnpDeleteLockedDeviceNode+0x4d
ffffd000`20c8d8d0 fffff801`c26949c7 : ffffe000`011e8880 ffffd000`00000002 00000000`00000000 00000000`00000000 : nt!PnpDeleteLockedDeviceNodes+0x9a
ffffd000`20c8d950 fffff801`c268ea15 : ffffc000`0261fd00 00000000`00000001 ffffc000`00000000 ffffe000`ffffffff : nt!PnpProcessQueryRemoveAndEject+0x4ef
ffffd000`20c8dab0 fffff801`c268ed4f : ffffc000`0261fda0 00000000`00000000 00000000`00000000 fffff801`c268ea30 : nt!PnpProcessTargetDeviceEvent+0x9d
ffffd000`20c8daf0 fffff801`c22b33cd : fffff801`c268ea30 ffffc000`0133baf0 ffffd000`20c8dbd0 ffffe000`04120ea0 : nt!PnpDeviceEventWorker+0x31f
ffffd000`20c8db50 fffff801`c235e664 : 29292929`29292929 ffffe000`0010f040 ffffe000`0010f040 ffffe000`000e4040 : nt!ExpWorkerThread+0x2b5
ffffd000`20c8dc00 fffff801`c23cd6c6 : fffff801`c2568180 ffffe000`0010f040 fffff801`c25c0a80 29292929`29292929 : nt!PspSystemThreadStartup+0x58
ffffd000`20c8dc60 00000000`00000000 : ffffd000`20c8e000 ffffd000`20c88000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: 0xc4_62_VRF_LEAKED_POOL_IMAGE_e1i63x64.sys
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0xc4_62_vrf_leaked_pool_image_e1i63x64.sys
FAILURE_ID_HASH: {59f6d737-59ca-a5da-318f-81cc8365781f}
