<><> Apologies if this has been posted in the wrong place <><>
Ok I'll keep this brief.
Problem:- LAN regulary disconnects and reconnets 30 seconds later.
Symptons:- Loose connection to Lan / Internet for around 30 seconds.
Background:- Had this problem with both P8P67 B2 and P8P67 pro boards. I have several other computers connected to the switch (not hub) and they are working fine. Have replaced the lead to no avail. Have even used the same lead in several other computers which works fine.
Config:-
Study
Netgear 8 port SWITCH 10/100/1000
Server
VOIP
PC
Switch connected to lounge hard wired via outdoor sheilded cat6 lead.
Lounge
Router
XBOX 360
Wii
Message in System Event Logs;-
Warning message - date time - source = e1cexpress
Event ID = 27
Intel 82579V Gigabit Network Connection
- Network link is disconnected
Then it states its connected again.
Have also tried the following;-
Remove Kaspersky 2011
Ensure ALL power management even OS is disabled
Use IPV4 instead of IPv6 in prefix policies
Disable nativue IPv6
Disable tunnel IPv6
Disable IPv6
netsh interface tcp set global rss=disabled
netsh interface tcp set global autotuninglevel=disabled
netsh int ip set global taskoffload=disabled
Disabled SNP;-
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\Parameters]
EnableTCPChimney=dword:00000000
EnableTCPA=dword:00000000
EnableRSS=dword:00000000
Have tried driver from Asus MB CD, Asus Website, Your Website, Windows Update all to no avail.
Please help.
- « Previous
- Next »
Hello friends,
I have a trouble and my networkcard isnt working anymore.
My NIC's eeprom 82579V integrated into ASUS P8Z77-V PRO motherboard is damaged/corrupted.
I will be really appreciated if you could dump Intel 82579V into .eep image file with Intel's eeupdate.exe in DOS.
Is it that where you can help me? I really need my NIC alive..
You can contact me in Skype: neuromask
Hope for anyones help. If it works, reward is coming
Thank you!
- « Previous
- Next »
