Ethernet Products
5821 Discussions
Intel 82580 1000 Base-X (fiber) TX clock source
Does intel 82580 1000Base-X(fiber) transmit clock use local reference clock or
rx recovered clock ?
Thanks in advance.
st4
New Contributor III
Hi HappyMan,
Let me check on this.
rgds,
wb
st4
New Contributor III
Hi HappyMan,
Good day. I am not an expert on this but manage to find the datasheet for this chipset , you may refer to the datasheet for reference:
http://www.intel.com/content/dam/doc/datasheet/82580-eb-db-gbe-controller-datasheet.pdf http://www.intel.com/content/dam/doc/datasheet/82580-eb-db-gbe-controller-datasheet.pdf
rds,
wb
