The product Intel82583V has 8 PHY pins and the pins is bi-directional, I want to know these 8 pins how to connect to the RJ45 after a transformer.
I see the RJ45'S connect method is that the pin4,pin5,pin7 and pin8 don't use.
Hello Jessies,
Thank you for contacting Intel® technical support. I will be more than happy to help you.
I understand that you need assistance with an Intel® 82583V Gigabit Ethernet Controller. The support for this device is provided by another Intel® department. I am transferring your post to the department in charge so they can assist you as soon as possible.
Xavier A.
Hi Jessies,
Thank you for writing in Wired Communities. Please be informed this inquiry is best support by our embedded support team, you may submit your inquiry at https://embedded.communities.intel.com/community/en
Thank you.
Sharon
