Ethernet Products
5716 Discussions
Intel ANS and Citrix PVS conflict
When i install Citrix PVS (v5.6 and 6.1) software onto a Dell r620 with Intel x520 NIC. It breaks any vlans I have setup.
It appears that the Citrix PVS software is breaking the Intel ANS software during the boot stages.
If I boot the server, then create the vlans after the server has booted they work fine.
If i reboot after creating them the server boots and the vlans are broken (no connectivity on that vlan).
Its like creating the vlan "after" boot time loads/reloads the ANS driver which then sits on top of the Citrix PVS driver enabling it to work correctly.
Any ideas how to fix this?
Ant.
Mark_H_Intel
Hi Anthony,
I did some research, and I think I found your answer on the Citrix web site:
http://support.citrix.com/proddocs/topic/provisioning-56/pvs-nics-requirements-teaming.html http://support.citrix.com/proddocs/topic/provisioning-56/pvs-nics-requirements-teaming.html.
The main thing is you have to configure all ANS interfaces before installing the provisioning services.
Mark H
