Ethernet Products
5534 Discussions
Intel Boot Agent - CL and GE
SSmit31
Can someone point me in the right direction or a KB article or explain what is the different between the different Intel Boot Agents.
Recently I've been seeing the following:
CL
GE
FE
Is there a matrix that explains the differences?
Or could be be product developments, FE became GE which became CL (or something like that)
st4
New Contributor III
Hi j3176040,
Just to double check where did you see CL, GE or FE bootagent version, so that we can further check.
Here is a reference website about Intel bootagent , you may check this out for reference
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005992.html How to Update Intel® Boot Agent for Network and I O
rgds
wb
SSmit31
We have some Dell Precision 7710, Other Dell's, HP and standard Asus motherboards. Its a big mix really.
PXE-E61: Media test failure, check cable PXE-M0F: Exiting Intel Boot Agent (Intel CL v0.1.05)
We also have others that looks like this:
http://trekker.net/wp-content/uploads/2013/08/optiplex_990_not_pxe_booting.png
So three different Boot Agents, CL, GE and FE, with completely different version numbers.
st4
New Contributor III
Hi j3176040,
Thank you for the additional info. let me check on this.
rgds
wb
SSmit31
Thanks, looking forward to hear more about this.
I know it might sound like a small request, but its actually quite important for us.
SSmit31
Is there any update to this?
st4
New Contributor III
Hi J3176040,
Apologize for the delay. We are checking if the GE and FE refers to different NIC model
rgds,
wb
SSmit31
Hi
I'm more interested in the GE vs the CL. We see a lot more of these on our PC's.
SSmit31
Any update to this?
st4
New Contributor III
Hi J3176040,
I am sorry there is no update yet.
rgds,
wb
SSmit31
Any update on this, how many months do you need?
This should be fairly well documented. Someone in Intel is developing this, but there are no readme notes and any doco of the sort. Not good Intel!!
st4
New Contributor III
Hi j3176040,
I apologize for the delay. I received information as below:
FE=fast ethernet; GE=Gigabit ethernet; XE = 10Gigabit Ethernet; CL = command line
rgd,
wb
SSmit31
Thanks, this now makes sense.
Can you ask what the difference between CL and GE is (as per opening/title)
We have 1Gbe Intel NIC's booting with CL and other 1Gbe using GE. In fact, we could load a CL or GE OPROM and they would both work, so the ROM supports the Intel hardware (NIC), but what's the difference in the software?
st4
New Contributor III
Hi j3176040,
Thanks, I will look further into this.
rgds,
wb
st4
New Contributor III
Hi J3176040,
Good day. Here are the information I confirm:
CL refers to clients supports, which is for the Gigabit LOM's. (Desktop Lan On Motherboard)
GE refers to supports for server silicon. (Server Adapters) .
Hope these clarifies your concern.
rgds,
wb
SSmit31
Thanks, That's good enough.
