Ethernet Products
5387 Discussions
Intel Corporation Ethernet Controller 10 Gigabit X540-AT2 - does it require AES-NI capable processor for IPsec offload?
rajeshsg
I would like to know if Intel Corporation Ethernet Controller 10 Gigabit X540-AT2 requires AES-NI capable processor for IPsec offload? Being PCIe device would it be able to work with aes-ni offload to processor?
Rajesh
Caguicla_Intel
Hello rajeshsg, Thank you for posting in Intel Ethernet Communities. We will check your query and get back to you once done. Hoping for your patience. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello rajeshsg, Thank you for the patience on this matter. Based on Intel® Ethernet Controller X540 datasheet, it has integrated IPsec security engines and supports AES-GCM 128-bit; AH or ESP encapsulation, IPv4 and IPv6 up to 1024 SA / port. You might want to check this on the link below on page 14: https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/ethernet-x540-datasheet.pdf Let us know if you have additional questions. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello rajeshsg, Kindly let us know if the information above answers your query. If you have questions and clarifications, please do not hesitate to ask. Looking forward to your response. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello rajeshsg, Please let us know if you need other assistance for this matter. Looking forward to your response. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello rajeshsg, We'd like to double check the model of your controller. Please provide the System Support Utility log of your system. This will allow us to check your Adapter details. 1- Download from https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- 2- Open SSU.exe 3- Mark the box "Everything" and then click "Scan". 4- When finished scanning, click "Next". 5- Click on "Save" and attach the file to a post. Your prompt reply is highly appreciated. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello rajeshsg, We would highly appreciate if you can share to us where the Ethernet Controller 10 Gigabit X540-AT2 is integrated to. If this is an OEM on-board Ethernet controller, it would be best if you can get in touch with your manufacturer for further support since they might have customized drivers and software to enable or alter features on your system. Please visit this link for Support Options for Intel® Ethernet Controllers https://www.intel.com/content/www/us/en/support/articles/000006628/network-and-i-o/ethernet-products.html?wapkw=oem+network Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
