Ethernet Products
5821 Discussions
Intel E10GSFPLR and Cisco SFP-10G-LRM Compatibility
AWood5
I wonder if someone can help me with a seemingly simple but elusive question. I'm looking to
make a purchase of several Cisco SFP-10G-LRM modules to support 10Gb communications over our
OS2 fibre infrastructure. All runs are less than 300m so this is cost effective compared to
using SFP-10G-LR.
On the other end of the fibre will be some servers using Intel E10GSFPLR optics at 10Gb.
My question is this - are these optics compatible for the situation I've described? I've done
some searching and can't find any definite information either way, despite these being popular
choices (I guess).
Any help is appreciated.
Andrew
SYeo3
Valued Contributor I
Dear Fencer128,
Thank you for contacting Intel.
The http://www.intel.com/content/dam/doc/product-brief/ethernet-sfp-optics-brief.pdf Intel® Ethernet SFP+ LR Optic (E10GSFPLR) can support 10GBASE-LR 10G Ethernet and 1000BASE-LX 1G Ethernet only. In relation to your concerns on compatibility with 10GBASE-LRM, I will help you check on this further.
I will update you on my findings.
Sincerely,
Sandy
AWood5
Thanks Sandy. For reference, the SFP-10G-LRM runs at 1310nm the same as the Intel optics, so I am hopeful. We run plenty of Cisco-Cisco over OS2 (<300m) without issue but haven't started deploying the Intel-Cisco scenario above. We're looking at around 100 pairs just now so the saving over using SFP-10G-LR is significant if you can validate.
Andrew
JArch4
Andrew,
Were you ever able to confirm if the Intel LR module will work with the Cisco LRM module on the other end? I'm in the same boat and the Cisco LR modules are over $1200.
AWood5
Hi Sandy,
I was just wondering how you were getting on with this one. Any joy? We are nearly in a position to purchase if it is looking promising.
Andrew
SYeo3
Hi Andrew,
Sorry for my late reply. Still no updates on this. I will follow-up on this internally.
Thank you for your patience and understanding.
Sincerely,
Sandy
AWood5
Hi Sandy,
I understand. I'd rather wait a bit longer to get an accurate answer than rush it and not.
Andrew
SYeo3
Hi Andrew,
While I'm checking on this with our team, you may also check with Cisco* if the LRM module can be connected to LR module.
Since they have both the LR and LRM modules available.
Sincerely,
Sandy
SYeo3
Hi Andrew,
I'm sorry to inform you that we can confirm on compatibility between Intel E10GSFPLR and Cisco SFP-10G-LRM as we aren't able to perform thorough testing on this type of connection.
We suggest that you may further check this with Cisco*.
Again, thank you for contacting Intel.
Sincerely,
Sandy
