Ethernet Products
5821 Discussions
Intel E810-2CQDA2 only one port showing up
icylane114
Any advice or help would be appreciated in setting up an Intel E810-2CQDA2 adapter on a new server with OpenSUSE 15.3. So far I've only installed the base driver ice-1.7.16 and nvm 3.10
But only one port is showing up for this dual-port adapter in EPCT configuration. Is there a configuration setting I'm not aware of or additional driver I need to install?
My machine is a Lenovo 7z23 2U server with PCIe 4.0.
EPCT version: v1.37.34.03
Copyright 2019 - 2021 Intel Corporation.
NIC Seg:Bus:Fun Ven-Dev Connector Ports Speed Quads Lanes per PF
1) 000:152:00 8086-1592 QSFP 1 100 Gbps Single 4
Ethernet Port Configuration Tool
NIC Seg:Bus Ven-Dev Mode Adapter Name
1) 000:152 8086-1592 100 Intel(R) Ethernet Network Adapter E810-2C-Q2
Available Port Options:
Port Quad 0 Quad 1
Option Option (Gbps) L0 L1 L2 L3 L4 L5 L6 L7
Active 100 -> 100 - - - - - - -
2x50 -> 50 - 50 - - - - -
4x25 -> 25 25 25 25 - - - -
