Ethernet Products
5741 Discussions
Intel E810-CAM1 Error Message in Ubuntu
Tommy0923
After Ubuntu installs the driver, after executing {dmesg | grep -i "Failed to read"}, an error "Failed to read Tx Scheduler Tree - User Selection data from flah" appears.
OS: Ubuntu 22.04.1 LTS (GNU/Linux 6.2.0-33-generic x86_64)
Driver version: Ice-1.12.7
Sazirah
Hi Tommy0923,
This is regarding your issue 'Intel Ethernet Controller E810-CAM1 driver failed to load after updated on Linux'.
We understand you have submitted your enquiry in our web portal with us and we will continue to help you through that case #06033418 now. We will therefore close this community case #06033974.
Sazzy_Intel
Tommy0923
Hi Intel team,
Case #06033418 is not currently available for inquiry on the portal, so will this community case #06033974 remain open?
