Ethernet Products
5821 Discussions
Intel E810-CAM1 NVM Configuration
C_KE
We've got an issue configuring Intel E810-CAM1 via nvm image.
The ethernet controller should provide 4 x 10G SFP+.
I couldn't figure out the right tool to execute the initial programming of the blank flash.
As far as I know, eeupdate64e and lanconf64e are not supported by 800 Series Controllers, while nvmupdate64e is used for updates of already programmed nvms.
I'm also searching for the right nvm image for a 4 x 10G SFP+ application.
Can you help me out with the right tool and nvm image?
Best regards
Chris
pujeeth
Hello IPE_CKE,
Greetings!!
We have received your query regarding configuring the Intel® E810-CAM1 Ethernet Controller via NVM image.
To assist you further, we kindly request you to provide the following information:
  1. Product Markings and Image – A clear photo showing all visible markings on the adapter.
  2. System Details – The complete system information where the controller is installed.
Once we receive the requested details, we will be able to proceed with the necessary steps to support your configuration request.
Pujeeth
C_KE
Hello Pujeeth,
the controller is set to provide 4x 10G SFP+.
The system is self developed and not out-of-shelf.
Christoph Keil
IntelSupport
Community Manager
Hi IPE_CKE,
Thanks for your response, could you please share the system details where the ethernet controller has been used.
Jerome
C_KE
Hi Jerome,
it's an self developed NIC-Board, containing Intel E810-CAM1 Controller, blank qspi flash, an sfp+ cage and needed peripherals (power sourcing etc.). The system is running on linux.
Please let me know if you need any more information.
Christoph
Akshaya1
Hi Hi IPE_CKE,
Thank you for your response.
To assist you further, could you kindly provide the motherboard details?
Akshaya
pujeeth
Hello IPE_CKE,
Greetings!!
We understand that you are attempting to perform the initial programming of a blank flash on the Intel® E810-CAM1 Ethernet Controller, with the goal of enabling a 4 x 10G SFP+ configuration.
To ensure you receive the most accurate and effective support, we kindly recommend that you post your query in the Intel Embedded Community Forum
Embedded community:
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Pujeeth
