Ethernet Products
5736 Discussions
Intel E810XXVDA2 ubuntu 22.04 timeout
Rackmounts
The customer states that they are using the latest ICE driver, and they need to make sure that when the kernel updates, that it wont break the driver. Mellanox for example does this (doesnt break).
question is:
- How can the client install the latest ice intel drivers deb (ubuntu 22.04 6.2) and be kernel supported (not to break when kernel is updated)
- Does this work with ice.pkg and update to the latest?
ethtool -i enp24s0f1np1
driver: ice
version: 6.2.0-37-generic
firmware-version: 4.30 0x8001af27 1.3429.0
expansion-rom-version:
bus-info: 0000:18:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Fariz_Intel
Hi Rackmounts,
We believe the alternative approach is to use dynamic kernel module support (DKMS). You can refer to the external link below for more details.
how to automatically build a kernel module with DKMS on Linux
https://www.xmodulo.com/build-kernel-module-dkms-linux.html
Compile Intel ice driver with DKMS for E810 card with PPS
https://support.timebeat.app/hc/en-gb/articles/13199965947026-Compile-Intel-ice-driver-with-DKMS-for-E810-card-with-PPS
Fariz_Intel
Fariz_Intel
Hi Rackmounts,
If you need more information or have any inquiries, let us know.
Fariz_Intel
Fariz_Intel
Hi Rackmounts,
Fariz_Intel
