Ethernet Products
5821 Discussions
Intel Ethernet ALB Bug with Microsoft Failover Clustering in 2008R2
A few of us users on Server Fault seem to have run into a bug with Microsoft failover clustering when Teaming ALB is enabled. What seems to happen is that sometimes after the virtual is moved from a server and transfered to another, the moment cluster ip address has a conflict with another cluster node on the network.
If the NIC Teaming is disable,the error will no happen.
Any ideas?
Mark_H_Intel
I found an earlier question on this same thing at /message/167492 http://communities.intel.com/message/167492. Instead of having two threads for the same issue, please use that thread for the discussion.
I am going to close this thread.
Mark H
