Ethernet Products
5719 Discussions
Intel Ethernet Connection X552/x557-AT Can't drive
panchuane
Proxmox VE6.4 Prompt at startup:
ixgbe 0000:03:00.1: Warning firmware error detected FWSM: 0x00300000
ixgbe 0000:03:00.1: The EEPROM Checksum Is Not Valid
ixgbe: probe of 0000:03:00.1 failed with error -5
use EEUPDATE get eeprom version:
Mike_Intel
Hello panchuane,
For us to further check and investigate the issue, please provide the following details.
  1. Are you using an onboard X552?
  2. Are you trying to update the firmware of X552?
  3. Can you further explain the issue?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
panchuane
1.yes,I using an onboard X552.
2.I want to update the firmware of X552, But I don't know how to update,And I don't have the firmware package.
3.I typed 'lspci -nn' to find the hardware device,But the network connection fails after the network cable is inserted,The led of RJ45 is not bright .
Mike_Intel
Hello panchuane,
Thank you for the update. Can you tell us the brand model of the board or the system that you are using.
Michael L.
panchuane
Mike_Intel
Hello panchuane,
Thank you for the quick reply. Since you are using an onboard X552 network card on a SuperMicro system, it is best to contact them on how to update the firmware of the network card. The reason for that is each system has their own file and they have different procedures on how to update the firmware. Just to add, you can use Intel's NVM firmware update file on OEM network card and vice versa because it may damage the card.
At this point, the best support team is the manufacturer of your system. Please contact them for further assistance. You may start on this link and click on support.
https://www.supermicro.com/en/products/motherboard/X10SDV-4C-TLN2F
Michael L.
Mike_Intel
Hello panchuane,
I hope this message finds you well. I am just checking if you are now talking to Supermicro for assistance on how to update the NVM firmware of the onboard network card.
Michael L.
Mike_Intel
Hello panchuane,
I hope you're having a wonderful day. I am just sending another follow up hoping that you already contacted SuperMicro for the NVM update assistance. Since we have not heard back from you, I need to close this inquiry.
If you need further assistance, please post a new question.
Thank you and stay safe.
Michael L.
