Ethernet Products
4855 Discussions
Intel® Ethernet Controller I225-V bsod e2f68.sys
scarer
1. Mainboard Gigabyte Z490 AORUS MASTER rev 1.0. BIOS f3.
2.DIMM2: Kingston HyperX KHX3733C19D4 / 16GX 16GB DDR4-3600 DDR4 SDRAM
DIMM4: Kingston HyperX KHX3733C19D4 / 16GX 16GB DDR4-3600 DDR4 SDRAM
4000 mhz
3.CPU Type OctalCore Intel Core i7-10700K, 5000 MHz (50 x 100)
4.Video adapter GeForce GTX 980 Ti (6 GB) pcie 16 3.0.
5.Corsair HX1000 power supply. about two years old to him.
6.1) KINGSTON SA1000M8960G Disk Drive (960GB)
2) Disk drive KINGSTON SA400S37480G (480 GB, SATA-III)
3) Disk drive KINGSTON SH103S3240G (240 GB, SATA-III)
4) Disk drive KINGSTON SH103S3240G (240 GB, SATA-III)
7. Everything was bought new.
8. Microsoft Windows 10 Pro. OS Version 10.0.19041.508 (Win10 20H1 [2004] Insider Preview)
9. connected through a surge protector.
10. The computer is overclocked, but it worked stably, passed all stress tests: aida 64, cinebench R20, cpu-z, prime 95.
Actually, what I accidentally noticed on my PC. The computer passed all stress tests perfectly, in everyday work I did not experience any problems after selecting the optimal voltages. But I accidentally turned on the CPU-z bench under additional load (google chrome + youtube), of course, the result became worse, but almost immediately I got a bsod with the error ntoskrnl.exe.
I started to understand and realized that the cause of the bsod data is the e2f68.sys driver (Intel (R) Ethernet Adapter NDIS driver). I tried versions: 1.0.0.13/1.0.1.4 (it did not work correctly, I encountered a problem that after a reboot the adapter did not work, it was necessary to completely turn off the PC, only then it started to work and so on until the reboot) /1.0.1.7/1.0 .1.8. With each driver I got bsod, but if I completely removed this driver and tried to enable video on youtube via the WIFI module, then the test in cpu-z went fine, with a lower result, but stable for about half an hour.
Also in the device manager with driver 1.0.1.8 such an error: There was a problem with starting the PCI device \ VEN_8086 & DEV_15F3 & SUBSYS_E0001458 & REV_01 \ 4 & 1ba68f3e & 0 & 00E3.
Driver name: oem81.inf
Class GUID: {4d36e972-e325-11ce-bfc1-08002be10318}
Service: e2fexpress
Lower filters:
Top filters:
Problem: 0x15
Problem status: 0x0
Actually the question is, perhaps this is a bug of the intel (R) ethernet controller i225-v driver, which manifests itself only in such a situation?
This error also occurs when watching 8k video.
if I completely remove the driver through the device manager, then I can safely pass the cpu-z with youtube video 1080p test or watch 8k video without bsod. but after reinstall driver for intel i225-v i got bsod again in the same situations.
any solutions for this problem?
Caguicla_Intel
Hello scarer,
Good day!
We are glad to hear that the problem was now resolved. Your effort in sharing the the issue resolution is highly appreciated. This will be helpful indeed to other users having the same problem.
Please be advised that we will now close this thread. If you need any additional information, please submit a new question as this thread will no longer being monitored
Thank you for choosing Intel!
Crisselle C
Intel® Customer Support
