Ethernet Products
5736 Discussions
Intel® Ethernet Controller I225-V disables itself
bencassar
We have an issue where Intel® Ethernet Controller I225-V disables itself.
  • Intel i225-v would disable itself and you cant re enable it
  • if you change and NIC settings it freezes device manager \ the settings box
  • rebooting the pc causes it to get stuck on the restarting page
  • adaptor goes back to normal and you can only re enable once a reboot has taken place
Motherboard: ASUS ProArt X670E-CREATOR WIFI AMD Motherboard
Intel® Ethernet Controller I225-V Driver V: 1.1.4.42
we have tried the usual remedies including driver updates \ re installs
Sazirah
Hi bencassar,
Regarding this issue, we need your assistance to provide us the SSU logs for us to analyze if there is any issue. Please follow the steps in the link below on how to obtain the SSU logs of your system:
If you have any other enquiries, please let me know.
Sazzy_Intel
bencassar
See attached
bencassar
1
Sazirah
Hi bencassar,
Thank you for the logs shared. We will be checking from our end and will revert to you as soon as possible.
Sazzy_Intel
Sazirah
Hi bencassar,
We have analyze the logs and since you are currently using ASUS ProArt X670E-CREATOR WIFI AMD Motherboard, you may try using the latest Asus driver from Asus website:
https://www.asus.com/in/motherboards-components/motherboards/proart/proart-x670e-creator-wifi/helpdesk_download?model2Name=ProArt-X670E-CREATOR-WIFI
If still an issue, you may try to do clean driver installation:
https://www.intel.com/content/www/us/en/support/articles/000058304/ethernet-products.html
Sazzy_Intel
bencassar
This was already done please advise , this is bigger than drivers etc
Sazirah
Hi bencassar,
May I know if you have done the clean driver installation? If yes, may I know the outcome?
Also, would like to check if you have tried contact Asus support regarding this?
Sazzy_Intel
Kae1
Hi Sazirah,
We have done a clean install and still same issue
Sazirah
Hi Kae1,
Thank you for your response. Let me check from our end and get back to you for the next solution.
Sazzy_Intel
bencassar
Hello Any update on findings ?
Sazirah
Hi bencassar,
Since the previous resolution still not fixing the issue, please follow below link for the next step of resolution:
Network Issues with Intel® Ethernet Controller I225-V
https://www.intel.com/content/www/us/en/support/articles/000057261/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
Sazzy_Intel
Sazirah
Hi bencassar,
Good day,
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
Sazirah
Hi bencassar,
Good day
This is regarding your enquiries above. Since we have not seen an update, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
