Hi, I have an Intel network adapter Ethernet Server Adapter X520-DA2,
you know if it is compatible with Nexenta CE version 3.1.6 FP3
I tried to add it but do not see it from the available adapters.
With the lspci -v command displays the following information. They can be useful?
Thank you
Paolo
07:00.0 Ethernet controller: Intel Corporation Unknown device 1572 (rev 01)
Subsystem: Intel Corporation Unknown device 0007
Flags: bus master, fast devsel, latency 0, IRQ 10
Memory at f8000000 (64-bit, prefetchable)
Memory at f7ff8000 (64-bit, prefetchable)
Expansion ROM at fbb00000 [disabled]
Capabilities: [40] Power Management version 3
Capabilities: [50] Message Signalled Interrupts: Mask+ 64bit+ Queue=0/0 Enable-
Capabilities: [70] MSI-X: Enable- Mask- TabSize=129
Capabilities: [a0] Express Endpoint IRQ 0
Capabilities: [e0] Vital Product Data
07:00.1 Ethernet controller: Intel Corporation Unknown device 1572 (rev 01)
Subsystem: Intel Corporation Unknown device 0000
Memory at f9800000 (64-bit, prefetchable)
Memory at f97f8000 (64-bit, prefetchable)
Expansion ROM at fbb80000 [disabled]
Hi Paolo,
Thank you for contacting Intel.
With regards to your inquiry on compatibility, it would be best if you can check with Nexenta* regarding the issue.
Hope you are able to fix the issue at the soonest.
Sincerely,
Sandy
