Ethernet Products
5821 Discussions
Intel® Ethernet Converged Network Adapter X550
ZubinPolra
I am using Intel® Ethernet Converged Network Adapter X550 with Windows 10. I am using lanconfiguration tool to put that in Test Mode 4 Dual Tone Test menu got same frequency value for 2.5GBase-T,5GBase-T and 10GBase-T speed(attached screenshot for reference) which is not expected. Those frequency values should be different for all speed.
Thanking you in advance
Zubin Polra
IntelSupport
Community Manager
Hi Zubin Polra,
Thank you for contacting Intel Ethernet Community.
May I verify if you have an IPS (Intel Premier Support) account?
IPS may have further information in regards on the tool used in this test scenario, which is lanconf.
URL login for IPS: http://premiersupport.intel.com/
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
BY_Intel
ZubinPolra
Yes, I have RDC privileged account that is Premier account but when I used to login to http://premiersupport.intel.com/ it keeps refreshing page and does not go ahed.
B_Y
Hi Zubin Polra,
May I know if you were able to login previously?
Have you tried on different browser to login to the website? The page refresh infinitely could be due to web cache glitch.
BY_Intel
ZubinPolra
I never login to http://premiersupport.intel.com/ before.
FYI: I am able to login here and https://designintools.intel.com/intel-network-connections-tools.html with my RDC privileged account.
B_Y
Hi Zubin Polra,
We got some feedback from development team for lanconf,
Yes, this is expected behavior – this is where we can choose which test mode will be tested
And for 2.5, 5 and 10G they are the same
These are the test frequencies, not the frequency of the actual signal.
We hope this answer your inquiries. Please let us know if there is anything else we can assist?
BY_Intel
B_Y
Hi Zubin Polra,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post.
In case we do not hear from you, I will make a follow up on March 9th 2023 . Thank you.
BY_Intel
B_Y
Hi Zubin Polra,
ince we have not seen an update for several days, if you need any additional information, please submit a new question as this thread will no longer be monitored.
BY_Intel
ZubinPolra
We had checked with oscilloscope that when we run DT1 signal,  oscilloscope shows frequencies between 36MHz and 41.4MHz.
We noticed for simillar for other signal like DT2... etc for all three modes: 2.5G, 5% and 10G.
Zubin.
