Ethernet Products
5821 Discussions
Intel Ethernet Switch FM4000 series registers description
OMilo
Good day! I'm using NAT MCH module with Hub-Module XAUI x48. This Hub-Module is based upon Intel Ethernet Switch FM4000 series.
The problem is that Hub-Module uplink ports doesn't support 1 Gbit Ethernet, only 10 GbE. These uplink ports are connected to switch
ports 3 and 8 respectively
I'd like to know how to enable 1 Gbit Ethernet support at switch ports 3 and 8?
And also could you, please, send me FM4000 series manual with on-chip registers contents to test the product?
Best regards, Miloserdin Oleg
