Ethernet Products
5821 Discussions
Intel I217-LM Power Management
I am imaging using SCCM 2012 R2. It installs the driver correctly but I would like to remove the check from "Allow the computer to turn off this device to save power". What is the best way to do this? Can I run a command line or a script to change that setting?
I need to change it for both Windows 7 and Windows 8.1 in case I have to do it differently.
Any help would be much appreciated.
Rick
SSalm
Hi Rick,
I'm afraid that I don't know the answer to your question, however I wanted to ask you a question as we are also imaging machines using SCCM 2012 that have these nic's.
We are finding high UDP packet loss which is affecting programs such as Lync that use real time video. We've also tested using iperf and can see high packet loss.
Have you seen issues similar to this?
Steve
