Ethernet Products
5736 Discussions
Intel I219-V / Change VLAN Windows 11
blehnchen
Hello all ,
im using a ThinkPad L14 Gen 5, what got the Network Adapter from Intel (18) I219-V. The System in running on Windows 11
I'm wondering where the option is to change the VLAN Tag on this Adapter has i can't find it
I tried to update/downgrade the Adapter without success
Any suggestions i added a couple of screenshots
Subhashish
Hello blehnchen,
Greetings !!
Thank you for your post. The features you are looking for (to change the VLAN tag will require Intel PROSET. As you are using windows 11, you will not be able to use Intel PROSET. Please refer to below article:
https://www.intel.com/content/www/us/en/support/articles/000087483/ethernet-products.html
Also, as this is an OEM unit (Lenovo System) and controller I219 is built-in (LOM), we suggest you to check with Lenovo support if there is any alternate way this can achieved.
As there is no further action required from our end, we will proceed to close this ticket. Thank you for your understanding.
Subhashish_Intel.
