Hi @ all,
I want to use an Intel I340-F4 Card in an enviroment, where there is only TX comminucations and no RX. (unidirectional communication)
I'am using the Linux igb driver on an 64-Bit Ubuntu.
Is it possible to use only one channel? And how?
Chris
Hi Chris,
You will need both transmit and receive to establish the Ethernet link even if the data is only being sent in one direction.
Mark H
Chris,
We are facing the same problem, have you found a way to do it? Thanks!
Hi Hold,
Please refer to my post below. Thanks.
/message/290134# 290134 1. /message/290134# 290134 Re: i350-f2 unidirectional transferApr 8, 2015 3:56 AM (/message/289888# 289888 in response to Hold)
Hi Hold,
Thank you for contacting Intel.
The Intel® Ethernet Server Adapters with fiber optic connector requires that RX and TX ports be connected. The network adapter won't connect when only 1 port (RX or TX) is connected.
Sincerely,
Sandy
