Ethernet Products
5521 Discussions
Intel® I350 Quad GBE Controller
AJ6
Hello every one
I am using this Intel® I350 Quad GBE Controller phy which is having a serdes port as well as MDII Interface .with pci as input , I are not using any MDII Interface I am using only serdes interface connected to an SFP module when an optical based SFP module IT is transmitting and receiving the packets when verified with LAN configration tool but When we use Copper Based SFP the packets are not transmitting and receiving ,the emprom setting we use were provided by intel .we are using I350_2-4port_SerdesFiber_NO-MNG_1_63 eprom settings for fiber which settings to be used for copper ? When diagonised with lAN it is proving LINK failure
thanks and regards
AGXIN.J
st4
New Contributor III
Hi AGXIN.J.
Thanks for the post. Let me further check on this.
rgds
wb
st4
New Contributor III
Hi AGXINJ
Please use the SGMII NVM instead of the Serdes NVM for SFP mods.
Hope this helps.
rgds,
wb
