Ethernet Products
5442 Discussions
Intel I350 removes VLAN information on received packets
karl4
I have an Intel I350-T4 and two USB to Ethernet adapter. The two NIC are connected to a network switch.
If I send tagged packets one of the adapters to the switch. I see in Wireshark that the VLAN tagged is removed for the I350, packets received in the other adapter is working as fine.
If I send tagged packets from the I350, I can see in the Wireshark that the packets are egressing with VLAN tag. The packets received in the two adapters are also with VLAN tag.
I have updated the drivers for the I350 NIC. I am also using a Windows 10 PC. Is there anything that I need to configure to prevent the I350 from stripping the VLAN information?
I tried using the I350 NIC on a Linux PC, and I'm seeing the VLAN information on the received packets just fined.
Any help would be appreciated.
Karl
Akshaya1
Hi karl4,
Thank you for posting in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and would like to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved, or if you require further assistance from us? Your prompt response will greatly help us in diagnosing and resolving the issue as quickly as possible.
We appreciate your patience and understanding, and we look forward to hearing from you soon.
Akshaya
karl4
Yes, I still have this issue
Akshaya1
Hi karl4,
Thank you for your response.
To assist you further, could you kindly share the system information, OS details, and the switch model at your earliest convenience?
Akshaya
karl4
Akshaya1
Hi karl4,
Greetings from Intel!
This is a reminder mail regarding the issue you reported to us.
We're eager to ensure a swift resolution and would appreciate any updates or additional information you can provide.
Akshaya
Akshaya1
Hi karl4,
We regret to inform you that this is an Operating System limitation since Windows 10 does not technically support Intel® Advanced Network Services (Intel® ANS). The only work around is to reconfigure VLANs once done with Windows update. If in case you have further inquires about the Windows validation, you may need to contact Microsoft for further assistance.
Here is the link for the list of Computer Manufacturer Support Websites:
https://www.intel.com/content/www/us/en/support/topics/oems.html
Direct link for Microsoft support:
https://support.microsoft.com/en-us/surface?ui=en-US&rs=en-US&ad=US
Akshaya
karl4
I'm able to send VLAN packets, using a packet generator, out of a network adapter. When packet travels out of the network adapter, to the switch, and then back to two another network adapters. One network adapter, USB to Ethernet, captures the packet with VLAN tag. The other network adapter, Intel I350, captures the packet without VLAN tag.
The Intel I350 is having issues where it is removing the VLAN tag. Do I need the Intel ANS, to get the I350 working properly?
Simon-Intel
Hi Karl4,
From our understanding, the I350 adapter is not accepting packets with VLAN tags, but outgoing packets seem unaffected. Additionally, this issue appears to be specific to the Windows 10 environment, as there are no issues in Linux. Kindly correct us if this is wrong.
To help us troubleshoot further, could you please provide the following details:
  1. Was the network adapter purchased directly from Intel or shipped with a system?
  2. Board details where the issue persists.
  3. Front and back pictures of the network adapter with the product markings clearly visible(if purchased directly from Intel).
  4. A link to the driver currently in use in your Windows 10 environment.
  5. Have you checked if the issue persists on other versions of the Windows operating system?
  6. Is it the same network adapter that works fine in the Linux environment, or is it a different one? If it’s a different adapter, please share the product markings.
  7. Complete details of the Linux operating system and board details where the adapter is functioning properly.
We also recommend reviewing our latest article on creating Intel® Advanced Network Services Teams and VLANs on Windows® 10. You can find it here:
Creating Intel® Advanced Network Services Teams and VLANs on Windows® 10
Please let us know if the issue persists after reviewing the article.
Simon
Akshaya1
Hi Karl4,
Akshaya
Akshaya1
Hi Karl4,
Thank you for contacting Intel.
As mentioned earlier, this is an operating system limitation, as Windows 10 does not technically support Intel® Advanced Network Services (Intel® ANS). As this is out of our scope of support, you may need to contact Microsoft for additional assistance.
 Hence, I will go ahead and close the case.
If you need assistance with any other concerns, feel free to reach out.
Akshaya
