Ethernet Products
5719 Discussions
Intel NIC i225-v network issue failed firmware upgrade
Benja86
Hi, I have a new Mother Gigabyte H470 Aorus Pro AX with the Intel NIC i225 running a linux ubuntu server 20.04 i just installed.  When I connect the the cable to a 10/100/1000Mbps Switch most of the time  de link is dead, and sometimes reboot after reboot the NICs is working but 1000Mbps (1Gb/s) instead of 2.5Gb/s, and the if i power off or reboot the link is again dead.
I tried to upgrade de firmware following the manual but i failed in the process.
  I ran nvmupdate64e por linux which  I found in the  intel 700Series package, placed the firmware FXVL_15F3_V_2MB_1.45.bin in the same folder and added at the end of nvmupdate.cfg:
BEGIN DEVICE
DEVICENAME: NNT
VENDOR: 8086
DEVICE: 15F3
SUBVENDOR: 1458
SUBDEVICE: E000
NVM IMAGE: FXVL_15F3_V_2MB_1.45.bin
IMAGE DOWNGRADE: TRUE
END DEVICE
During the interactive proccess read the legend "update available" i225-V NIC, I backup backup the nvm image and then when the upgrading fails.
Is there any missing variable/value in my config file? Did I miss something else?
This is some useful output from ubuntu server:
#lspci -knn
04:00.0 Ethernet controller [0200]: Intel Corporation Device [8086:15f3] (rev 02)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:e000]
Kernel driver in use: igc
Kernel modules: igc
ethtool enp4s0
Settings for enp4s0:
Supported ports: [ ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
2500baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
2500baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: Unknown!
Duplex: Unknown! (255)
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
MDI-X: off (auto)
Current message level: 0x00000007 (7)
drv probe link
Link detected: no
If you need more information about the system you are free to ask.
Benjamin.
AlfredoS_Intel
Hi Benja86,
Thank you for posting in our Intel® Ethernet Communities Page.
Kindly provide us the results of this command: ethtool -i ethx where ethx is the Ethernet port.
May we also know where have you downloaded the file, FXVL_15F3_V_2MB_1.45.bin? Have you downloaded it from the Gigabyte website? To confirm, the firmware download for the board which is on the gigabyte website, is not compatible with Linux, so that is why you are asking if we have tool for Linux, are we correct?
We look forward to hearing from you. If we do not get your reply, we will follow up after 3 business days.
Alfred S
Intel® Customer Support
AlfredoS_Intel
Hi Benja86,
We are just following up.
It looks like you need more time to provide the information that we asked.
We will follow up again after 3 business days. Should we not hear from you, our system may automatically close the thread.
Alfred S
