Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Intel® Network Adapter Driver for Windows® 10 Version: 25.2 (Latest) Date: 7/14/2020
Installed on windows 10 latest release, latest patch ....
In event viewer ; Event id 5038 in  windows log->security
Code integrity determined that the image hash of a file is not valid. The file could be corrupt due to unauthorized modification or the invalid hash could indicate a potential disk device error.
File Name: \Device\HarddiskVolume3\Program Files\Intel\Wired Networking\NCS2\Agent\Coinstaller.dll
In Windows log->Applications and Services Logs->microsoft->windows->CodeIntegrity->Operationnal
a lot of event id 3004 folowed by event id 3089
3004: Windows is unable to verify the image integrity of the file \Device\HarddiskVolume3\Windows\Installer\{FBDEEBC8-592A-415F-AD68-086A8EEFA433}\ARPPRODUCTICON.exe because file hash could not be found on the system. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
3089: Signature information for another event. Match using the Correlation Id.
Unstalling software (Proset 25.2) clear errors and functionnality...
Software and driver operating as expected - no problem to report
Just want to let you know... this is an annoying error...
Hi Wallabyjack,
Thank you for posting in our Intel® Ethernet Communities Page.
We are sorry to hear about the issue that you are experiencing with your network adapter.
To better assist you, we need to get some logs from your system. It will tell us the different driver version and components installed on your system. Please download and run our Intel® System Support Utility from this page, https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-. After running it, you will be given an option to save the logs to a text file, please do so and attach the file on your reply.
We look forward to hearing from you. If we do not get your reply, we will follow up after 3 business days.
Alfred S
Intel® Customer Support
Highlighted
as requested..
Highlighted
Hi Wallabyjack,
Thank you providing those information.
Please allow us some time to check on this.
We will get back to you no later than 3 business days from now.
Alfred S
Highlighted
Hi Wallabyjack,
Thank you for waiting for our update.
We were doing preliminary checks on your issue, and we find the need to ask these questions which can be helpful in determining a solution to your issue:
1. Does the issue only happen on the newest driver version (25.2)?
2. Did you experiencing it an older version of Windows 10 or driver?
We look forward to your reply. Should we not get your reply, we will follow up after three business days.
Highlighted
This is a brand new nic card to connect my brand new Qnap NAS...
I only downloaded the latest version (25.2) to make sure the trunking will function, but not yet configured..
Nerver have this issue with other drivers, but only using Windows 10 current version.
Willing to make a try if you tell me what to try...
Highlighted
Hi Wallabyjack,
Thank you for your response.
Please try to install this driver instead and see if you will get the same errors in event logs, https://downloadcenter.intel.com/download/29742/Intel-Ethernet-Adapter-Complete-Driver-Pack.
Kindly uninstall the 25.2 driver first if you left it installed, before you install this driver.
When we did a deep analysis on the logs, we also noticed that you have another ethernet card, Intel(R) 82599 10 Gigabit Dual Port Network Connection, is this the one that you are trying to update or the other,  built-in card, I219-V?
Alfred S
Highlighted
download completed...
uninstall completed...
clear event log... just to make sure...
intall completed...
configuration done again....
same error in error log
event id 5038 in windows log ->security
but has I have written... the software seem to work as expected...
And yes. this is for the 82599 10 gbit Dual Port... the I217-V work also fine...
I joint : windows security logs + windows system logs + SSu logs
Have a nice day!
Denys.
Highlighted
Hi Wallabyjack,
Thank you for your response and for trying our suggestions.
Based on your logs, it seems like something is blocking the file from being accessed:
1. Do you have an anti-virus or firewall installed on your system?
2. Is the storage, where you are copying the installer to, in a RAID volume?
Alfred S
Highlighted
Good morning!
1 - I'm running Microsoft AV and Microsoft Firewall that's all,
2 - No, it is installed on an SSD no raid there.
Have a nice day!
Denys.
Highlighted
Hi Wallabyjack,
We just want to confirm about the answers that you have provided.
Some advanced users, edit the inf files for the adapters. If a invalid entry was added or removed, these errors could happen. Have you also edited the .inf? You mentioned something about configuring something.
Alfred S
Highlighted
Bonjour,
no, I just downloaded the software and install it has it come...
the only thing I had mentionned was that I intend to activate the "trunking" on the 82599 dual port ... but not for now.
