Ethernet Products
4614 Discussions
Intel Network Adaptor Drive Windows 7 Wake Up Bug
Intel ProSet Drive installed in a Lenovo X61 laptop computer with 32bit Windows 7
system and Intel 82566MM Gigabyte Ethernet component,If the system sleeps
with AC adaptor and wired network on, and if the system is waked up with AC
adaptor and wired network off, then Intel Proset Drive will quickly use up all CPU
power, within 5 seconds the computer will freeze and you can do nothing but a
hard reboot. If wake up with AC adaptor and wired nerwork on, then there's no
such problem.
Uninstall Intel ProSet Drive and use Windows 7 native drive for Intel 82566MM
solves the problem. Reinstall ProSet will trigger the same problem. Have tested
the newest ProSet v14.8.3 and older versions v14.7 and v14.3, all have the same
problem.
Sungwha_S_Intel
Hello ujda765,
What do you mean by "wired network off"?
