Ethernet Products
4811 Discussions
Intel Network I225-V, status == link down
_viktor_
good afternoon.
purchased 'Asus ROG STRIX Z490-E GAMING ' motherboard with 'Intel Network I225-V' network card.
an unpleasant problem appears:
after rebooting or waking up from hibernation, the network card considers that the cable is not connected.
if through the device manager (or ncpa.cpl) turn off and turn on the card, then the network rises and everything works.
After the reboot, everything is again the same.
in the PROSet program "Cable Tests" shows:
 Cable Quality Status : Failed;
 Cable Integrity Status : Failed.
But "Connection Tests" and "Hardware Tests" shows everything has passed.
I attach the logs of the program SSU.
"log-i225-v-0.txt" this log after reboot when the network is down.
"log-i225-v-1.txt" this log after the procedure with turning off the device.
replacing the cable does not help.
AlfredoS_Intel
Hi _viktor_,
Thank you for posting in Intel® Ethernet Communities.
Thank you providing those logs.
Please allow us some time to check on this.
We will get back to you no later than 3 business days from now.
Alfred S
Intel® Customer Support
Jeneral_Pain
I had the same problem and found updating the firmware stopped this problem.
AlfredoS_Intel
Hi _viktor_,
We would like to check if the suggestions of our esteemed community members addressed your concern.
We look forward to hearing from you. Should we not hear from you, we will follow up after 3 business days.
Alfred S
AlfredoS_Intel
Hi _viktor_,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment. We know that this is important for you to get it resolved and it is also equally important for us to give you the right solution; as much as we would like to assist you, we need to close it to attend to other customers. We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
_viktor_v2
I could not answer because my account was blocked (I don’t know the reason, because support is not responding). this is my third account and I think it will be blocked until tomorrow.
on the question, none of the above helped. the manufacturer of the motherboard recommended taking it to a service center for diagnostics.
