Ethernet Products
5573 Discussions
Intel Onboard LAN Freeze System for seconds every serveral minutes.
CChan93
I am using an intel onboard ethernet I217-V with most updated driver e1d63x64.sys 12.8.33.0 (5/30/2013). I am using Windows 8 64-bit and recently I found the system freeze for seconds every serveral minutes. After struggle to debug for a long time, I use process monitor from Microsoft to see what happen inside. Everytime the system freeze, i found that there are over thousands of lines of below appear in the process monitor. After finding for a long time, I found that that is related to the LAN driver which write huge data to the registry repeatly at a very very short time such that make my system freeze. Restart my PC and router, reconnect the wire also do not help. Do you have any adivse?
3:27:43.8673634 AMSystem4RegCreateKeyHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28REPARSEDesired Access: Read/Write3:27:43.8674222 AMSystem4RegCreateKeyHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28SUCCESSDesired Access: Read/Write3:27:43.8675532 AMSystem4RegSetValueHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28\e41de5b068e28d43a41bf78d2cb819caSUCCESSType: REG_BINARY, Length: 96,064, Data: E8 03 00 00 00 00 00 00 FC 6B C8 AF FF 95 CE 013:27:43.8675996 AMSystem4RegCreateKeyHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28REPARSEDesired Access: Read/Write3:27:43.8676714 AMSystem4RegCreateKeyHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28SUCCESSDesired Access: Read/Write3:27:43.8679204 AMSystem4RegSetValueHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28\e41de5b068e28d43a41bf78d2cb819caSUCCESSType: REG_BINARY, Length: 96,064, Data: E8 03 00 00 00 00 00 00 FC 6B C8 AF FF 95 CE 013:27:43.8680395 AMSystem4RegCreateKeyHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28REPARSEDesired Access: Read/Write3:27:43.8680556 AMSystem4RegCreateKeyHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28REPARSEDesired Access: Read/Write3:27:43.8681080 AMSystem4RegCreateKeyHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28SUCCESSDesired Access: Read/Write3:27:43.8681234 AMSystem4RegCreateKeyHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28SUCCESSDesired Access: Read/Write3:27:43.8682133 AMSystem4RegSetValueHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28\e41de5b068e28d43a41bf78d2cb819caSUCCESSType: REG_BINARY, Length: 96,064, Data: E8 03 00 00 00 00 00 00 0E 93 C8 AF FF 95 CE 013:27:43.8684187 AMSystem4RegCreateKeyHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28REPARSEDesired Access: Read/Write3:27:43.8684664 AMSystem4RegCreateKeyHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28SUCCESSDesired Access: Read/Write3:27:43.8684903 AMSystem4RegSetValueHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28\e41de5b068e28d43a41bf78d2cb819caSUCCESSType: REG_BINARY, Length: 96,064, Data: E8 03 00 00 00 00 00 00 0E 93 C8 AF FF 95 CE 013:27:43.8687265 AMSystem4RegSetValueHKLM\System\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28\e41de5b068e28d43a41bf78d2cb819caSUCCESSType: REG_BINARY, Length: 96,064, Data: E8 03 00 00 00 00 00 00 0E 93 C8 AF FF 95 CE
