Ethernet Products
4630 Discussions
Intel PRO/1000 GT Dual server adapter EEPROM test failed
MSypc
Network card Intel PRO / 1000 GT Dual server adapter has been installed on the server. If the test produces an error EEPROM test failed, there have been reinstalled the driver, but the problem remained. Tell me what is connected with the problem and how to fix it.
AP16
Valued Contributor III
Card is working right now?
st4
New Contributor III
Hi Midgard,
Thank you for the post. What you can do is try to reflash the bootagent , download preboot.exe at https://downloadcenter.intel.com/download/19186/Intel-Ethernet-Connections-Boot-Utility-Preboot-images-and-EFI-Drivers Download Intel® Ethernet Connections Boot Utility, Preboot images, and EFI Drivers
Run and extract the fiel.
copy the bootutil.exe into a bootable dos disk.
Go to dos prompt to excute the following command:e.g
C:>bootutil to display the list of NIC on your system
if GT desktop is define as NIC 1,then run the ff command
c:>bootutil -NIC=1 -up=pxe
Please refer to this site for additonal bootutil command info:
http://www.intel.com/support/network/adapter/pro100/bootagent/sb/cs-008212.htm Intel® Boot Agent — Intel® Ethernet Flash Firmware Utility to Upgrade, Enable, or Disable Flash
Rgds,
wb
MSypc
thank you.We will try.
