Windows 7 SP1 x64 (Rampage III Gene - MB)
WMI service - working and started
IPRosetmonitor.exe - service working and started
I tried install and uninstal latest drivers with Intel PROSet and ANS
But I can't get teaming advanced tab in device manager
Please help!!!
There is a way to use your network connection in a team, but you will need to add an adapter. The desktop class network connections do not support creating a team, which is why you are not seeing a teaming tab. The good news is that the http://www.intel.com/products/desktop/adapters/gigabit-ct/gigabit-ct-overview.htm Intel® Gigabit CT Desktop Adapter doubles as an entry-level server adapter and provides a way to add teaming capability to your motherboard using the PCIe x4 slot. The Intel® Gigabit CT Desktop Adapter will have a teaming tab that permits you to create a team using that adapter and your onboard network connection.
Mark H
Mark H
Before updating to SP1 , IE9 I see teaming tab with Intel(R) Gigabit Ethernet Driver V10.1.9.0 for 32/64bit Windows XP & Windows Vista & Windows 7.(WHQL) from Asus site without adding any hardware...
I try reinstall old driver from Asus without success too.
Then I tried to install 16.2 without PROSet and ANS I can get advanced tab , but not as earlier with teaming from Intel...
