Ethernet Products
5741 Discussions
Intel(R) 82579V Gigabit Network Connection
Mame10
the internet connection doesn't work, even if the  RG-45 cable can not detect or blink the light.
Many methods are used to check the errors update the drivers, check the hardware, change the cable and firmware, antivirus checks, and other methods . but can not function .
Thank You
Mohammed kasim
n_scott_pearson
We need more information.
Please download and run the Intel System Support Utility for Windows. When you start the utility, select Everything and then click on Scan. Once it completes the scan process, click on Next and then Save. Pick a name for the text file to create and click on Save to create it. You can then close the app. Finally, open a response post here and then, using the Drag and drop here or browse files to attach dialog (below the edit box for the body of your response post), upload and attach this text file to the response post.
Fariz_Intel
Hi Mame10,
You can also try the loopback test by ping 127.0.0.1 (localhost). Feel free to share the SSU scan to further assist with your issue.
Fariz_Intel
Sazirah
Hi Mame10,
Good day.
I am following up on behalf of Fariz_Intel for this case.
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
Sazirah
Hi Mame10,
Good day.
This is regarding your enquiry above.
Since we have not seen an update, we will be closing this forum case from our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
