Ethernet Products
5614 Discussions
Intel(R) 82579V Gigabit Network(integrated into asus 5 gene) Connection only 10mbs
Vkise
asus 5 gene motherboard ,tried asus drivers(old,new) tried latest drivers from intel ,cat5e(checked on other pc full 1gbit no problem ),router capable of 1gbit used correct port ,had no problems before ,problems only ocurd recently ,when i try to force 1gbit connection pc freezes up and then lets off (cycles like that with no connection) no physical damage to port or motherboard visible,diagnostic tool says evrything is a-ok. what should i try to fix tyhis issue?
Mike_Intel
Hello Vkise,
To troubleshoot the issue, please try the following.
  1. Kindly update all the drivers.
  2. You may also update the BIOS of your board.
  3. Try to check your BIOS settings.
On my recommendations that involves updating the BIOS of your board and BIOS settings, please coordinate with your board manufacturer. For additional information, please open the link below:
https://www.intel.com/content/www/us/en/support/articles/000005658/network-and-i-o/ethernet-products.html
If you have questions, please let us know.
Michael L.
Intel Customer Support
Under Contract to Intel Corporation
Mike_Intel
Hello Vkise,
I am just checking of you tried our last recommendations. Kindly update us for us to further investigate this issue.
Michael L.
Mike_Intel
Hello Vkise,
Please update us if you tried our last recommendations.
Michael L.
