My PC is not able to connect to the Internet via ethernet cable, in fact it says that the cable is not plugged. The driver is updated, I tried to uninstall it, disable it. furthermore i have tried most of the solutions provided by youtube and i am hoping you guys can help me thanks.
Hello Kwenza,
For us to further check the issue, please provide the following details.
- Is it working before?
- If yes, how did the issue started?
- Are you using an onboard/embedded I219-LM?
- What is the brand and model of your board or PC?
- Did you try to replace the LAN cable?
- When you connect the LAN cable, kindly check if the LED in the LAN port.
- What re the other troubleshooting steps that you tried so far?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
1. Yes
2. When i installed a software called auslogics driver updater a few minutes it stopped working
3. onboard
4.PC model 7040 dell
5. No
6. I am using a router to connect to my pc via usb data cable.
7. i have tried resetting windows and updating to the latest version
- i also tried uninstalling the drivers and disabling it, overall i have tried 60% of the solutions still no luck.
Kwenza
Hello Kwenza,
Thank you for the quick reply and base on the information that you provided, here are my recommendations:
- Try using a different USB cable and connect it in the different USB socket.
- If your computer has LAN port, try to check if your system will have a connection via LAN port.
- When you said you have tried resetting Windows, did you mean re-installing the OS? If yes, have you also checked if the onboard LAN is enabled inside the BIOS?
- Can you share a screenshot of your device manager if there is an error on your network.
Michael L.
All sorted guys thanks for your advise. all i had to do was to install a new windows 10 (format) on my device, i suspect my drivers were outdated.
Hello Kwenza,
Thank you for updating us and we are glad that everything has been sorted out. I will close this thread now and you need assistance again in the future, please post a new question.
Thank you.
Michael L.
