Setup:
Problem:
Event Logs:
Things I have tried:
I have tried the following Intel drivers:
I have tried disabling all of the power management properties in the Intel driver properties
Hi casewindows,
Just to double check if you connect the ethernet port directly to the TP-Link ADSL2 Router, will this make any changes? Thanks.
rgds,
wb
Hi casewindows,
Please feel free to provide update for me to better assist on this.
rgds,
wb
Hi there, sorry about the delay in replying.
The router is on the other side of the house, it just isn't practical to hook it up directly.
I am tempted to try a different cable, but it seems unusual that the old cable worked with a Realtek based 1Gbps NIC for years on a GA-X38-DQ6 on Windows Vista 32bit and now this one has problems, only waking from sleep, on a much more modern board with an Intel NIC.
Unplugging and re-plugging either the end of the cable that goes into the NIC or the end of the cable that goes into the TP-Link gigabit 5 port switch fixes the problem without having to reboot.
It seems like there is some sort of sync problem when the system wakes from sleep.
Hi Casewindows,
Thank you for the reply. Can you try manually set Duplex & Speed to 100mbps Full
or is any setting in the BIOS to set the speed to 100mbps Full?
Tried to disable/enable the device, try to contact Gigabyte support if they have any customize driver (which I understand you did try installing their driver) of if they have any known issue or fix for this issue relates to their board as this is an onboard NIC.
If there is a chance you could change the cable or connect the cable directly to the router that could be of some help to isolate the issue.
thanks,
wb
Hi Casewindows,
Have you tried contacting Gigabyte to check on the hardware aspect on the onboard NIC. Please feel free to update me.
rgds,
wb
Hi Casewindows,
As an additional information, you may look into suggestions posted in our community sites,
please try checking with manufacturer for latest BIOS, disabling IPv6 mentioned in this thread - /thread/106797 https://communities.intel.com/thread/106797
Hope this helps.
rgds,
wb
I had exactly the same problem with a similar setup. Found a workaround : if I wake up from sleep using the computer case button, system works fine. If I wake up from sleep using the kb or mouse, I get the same problem as you do.
I queried gigabyte about this, they sent me a beta version of the latest bios but I didn't try it since my workaround fixes the issue.
Hi Nerfolt,
Thank you for sharing the information and glad the issue is fixed
Rgds,
wb
I have the exact same problem! Does it have a solution that does not require a workaroud? I don't think this is a solution, considering the price I paid for all new components that should work well out-of-the-box.
Thank you!
Hi AndrediP,
Have you contacted the board vendor for the issue? It is recommended to check with the board vendor http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006628.html?wapk...
Rgds,
wb
