Ethernet Products
5782 Discussions
Intel(R) Ethernet Connection (7) I219-V
Hugowe
Hello I recently flashed my BIOS with the latest version, and now my Intel(R) Ethernet Connection (7) I219-V is having start issues.
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
The most recent event is:
Device PCI\VEN_8086&DEV_15BC&SUBSYS_7B221462&REV_10\3&11583659&0&FE had a problem starting.
Driver Name: oem33.inf
Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
Service: e1dexpress
Lower Filters:
Upper Filters:
Problem: 0xA
Problem Status: 0xC0000001
Things I have tried:
Installing Intel's generic driver -
https://downloadcenter.intel.com/download/25016/Intel-Network-Adapter-Driver-for-Windows-10?product=...
and
Using the eeupdate folder to fix my MAC Address in BIOS being FF:FF:FF:FF:FF:FF by installing the system file iqvw64e.sys and executing EEUPDATEW64e -NIC=1 -MAC=<My Mac Address>
Resulting issue
https://ibb.co/4M4sW9w
NIC Bus Dev Fun Vendor-Device Branding string
1 0 31 06 8086-15BC Intel(R) Ethernet Connection (7) I219-V
1: Updating Mac Address to 309************...Done.
1: Updating Checksum and CRCs...Failed.
I am running Windows 10 Home build  19041 with no restore point
Motherboard Model: B360 GAMING PLUS (MS-7B22)
BIOS VER: E7B22IMS.2B0
Please help. Thanks!
Mike_Intel
Hello Hugowe,
I am really sorry to hear that. However, if your card is a 3rd party card, it will not accept Intel's firmware update software and vice versa. Since you are using an embedded network card, it is best to contact the manufacturer of the board on how to update the firmware of the network card.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days.
Thank you.
Michael L.
Intel Customer Support Technicians
Mike_Intel
Hello Hugowe,
I just want to check if you were able to speak to your board manufacturer regarding this issue?
Thank you.
Michael L.
Mike_Intel
Hello Hugowe,
I am just sending another follow up to check if you already contacted the manufacturer of the board.
If you need further assistance, please post a new question.
Thank you.
Michael L.
