Ethernet Products
5047 Discussions
Intel(R) Ethernet Controller I225-V Driver Software - disconnection
Y_P
I have problems with my Ethernet controller I225-V, which is installed on my Asus ROG Strix X670E-E. My Windows 11 pro is up to date and the driver from Intel is 2.1.4.2. I have adopted Pat_T's recommended settings and am testing them out.
Speed & duplex: Auto negotiation > Auto negotiation
Large Send Offload V2 (IPv4): Enabled > Disabled
Large Send Offload V2 (IPv6): Enabled > Disabled
TCP Checksum Offload (IPv4): Rx & Tx Enabled > Disabled
TCP Checksum Offload (IPv6): Rx & Tx Enabled > Disabled
UDP Checksum Offload (IPv4): Rx & Tx Enabled > Disabled
UDP Checksum Offload (IPv6): Rx & Tx Enabled > Disabled
The failures with the network are not good and I lack any creativity to improve anything here. Please give me an assessment of the SSU report.
I have also created a file with SSU - but do you recognize anything else that could help?
Side notes:
I have tried the same with the recommended (downloadable) Intel-driver from Asus-Website with number 2.1.3.3 - with same problems - disconnected lan.
replaced the mainboard three times (1x ROG Strix X670E-F and 2x ROG Strix X670E-E) with the same incidents = disconnections LAN after some time.
My distributor notebookbilliger.de as contracting partner told me to send the board to Asus (after 2 months warranty period) for checking. Intel told me today to speak with OEM partner (=Asus).
A really "perfect" situation for me....both - intel & distributor - refer and delegate the responsibility to Asus, although the component and the driver are from Intel.....but Asus is the manufacturer of the motherboard.
Maybe someone can help me...pls
kind regards
Yello
RyanFeeko
New Contributor II
Hey @Y_P , i have found some article and maybe related to your issue. Lets have a look the link below.
https://www.intel.com/content/www/us/en/support/articles/000057261/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
Hope this helps....
Fikri_Intel
Hi Y_P,
Thank you for reaching Intel Community.
Based on your query, may we confirm the I225-V is built-in with an ASUS motherboard or PCIE network card?
Fikri O.
Y_P
Good Morning Ryan & Fikri,
thanks...i will check the information / link....
My i225-V is built in with an Asus-Mainboard Rog Strix X670E-E.
Kind regards
Yello
Sachinks
Hello Y_P,
Greetings!
Thank you for the confirmation. Kindly follow the steps given in the link shared for the NVM update ( https://www.intel.com/content/www/us/en/support/articles/000057261/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html) and let us know if it resolves the issue.
Sachin KS
Y_P
ok...i will try it Sachin....
could be this the latest driver....it seems to be very old
2024_06_12_09_35_51_ROG_STRIX_X670E_E_GAMING_WIFI_Mainboards_ROG_Germany_Mozilla_Firefox.jpg
after all steps i will inform about the results...
"Update the NVM to the latest version."  ==> what is this?
kind regards
Yello
Poojitha
Hi Y_P,
Thank you for your response. We will wait for your further update to proceed further.
Poojitha
Y_P
sorry for asking...what is the “Non-Volatile Memory (NVM)” ? where can I find it?
Simon-Intel
Hi Y_P,
Good day!
An NVM (Non-Volatile Memory) firmware update refers to the process of updating the firmware stored in a device's non-volatile memory.
Firmware is a specialized type of software that provides low-level control for a device's specific hardware. Since your adapter is embedded in the system, we recommend contacting your OEM/Manufacturer for the firmware driver version that is compatible with your exact system.
Using software and firmware versions that have not been validated to work together may affect performance, feature availability, and system stability.
Simon
Y_P
Hello SImon,
thanks for the feedback. I've read everything, but I still don't understand exactly what I'm supposed to do and how. Maybe you can explain the NVM or send me a link where I can update this firmware. I assume that you don't mean the bios firmware. Sorry....but this is important to understand.
I followed the link and did everything so far - except NVM.
Update NVM -> open point for me
Install latest LAN Driver -> ok
But "Install LAN driver 1.0.1.4" confuses me a little bit because this guide is from 2022 .... is this still the version for today's use?
At the moment my network adapter looks like this (under Device Manager):
Sachinks
Hello Y_P,
Greetings!
Thank you for the update and thank you for providing the details.
NVM update is the firmware update for the I225-V Ethernet controller. In the previous link shared ( https://www.intel.com/content/www/us/en/support/articles/000057261/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html) Once you follow the steps 2 and go to the download center of the motherboard vendor and download the driver package, Inside the package, you will find the firmware update tool and instructions on how to use it.
You can use this firmware update tool the update the firmware of the controller ( NVM firmware). The full details are given as a note after the step3.
If you are not able to find this firmware update tool, I request you to contact the motherboard vendor once and check if they can provide the firmware update file from their end.
I hope this is helpful.
Sachin KS
Y_P
The file from Asus is named "DRV_LAN_Intel_I225_I226_TSD_W11_64_V11438_20230321R.zip"
Mainboard: Rog Strix X670E-E
https://rog.asus.com/de/motherboards/rog-strix/rog-strix-x670e-e-gaming-wifi-model/helpdesk_download/
Inside the ZIP file i can find these files:
I dont find the NVM firmware update tool.....sorry for this circumstance!
Sachinks
Hello Y_P,
Thank you for the update.
Since there is no firmware update tool in the zip file, I would request you to contact asus directly once and check with them for the firmware file.
As this is a built-in controller, they would have the details about the firmware for this particular controller from their end.
Sachin KS
Y_P
Could there please be a way that you can use your experience and knowledge with Asus to try and get the right tool? I wouldn't know how to describe it specifically and where to turn. It's not a classic customer care issue.
Unfortunately, I am not so experienced in expressing myself so well on the subject. Could be? Intel has contacts to Asus, i think.
Kind regards
Yello
Poojitha
Hi Y_P,
We apologize for any inconvenience caused. Unfortunately, we do not have direct access to ASUS support channels.
To ensure you receive the assistance you need, we kindly request you to contact ASUS directly using the following link:
https://www.asus.com/support/
If you encounter any challenges or have any questions, please feel free to reach out to us. We are happy to help you!
Poojitha N
RyanFeeko
New Contributor II
Hey @Y_P i have found ASUS forum where its like related to your issue:
https://rog-forum.asus.com/t5/amd-500-400-series/intel-i225-v-driver-update-not-working-on-rog-strix-b550-f/td-p/960918
Seems the issue like from ASUS firmware/driver/Bios but not sure how it goes.
Hope this may helps you a bit ....
Y_P
Thanks for the tip. I just couldn't find anything that would work for me.
I wrote to Asus support yesterday....hope to get a response. With all my details....and Infos.
For the NVM tool I downloaded the release "Release_29.1.1.1.zip" from Intel and there is also an "NVM Update Package".
Can't you also use that or does it have to be exactly what Asus has adapted? If there is one.
Sachinks
Hello Y_P,
Greetings!
Thank you for your reply!
Since you have confirmed that you have written to Asus, we would request you to wait for their reply in regards to this issue. Since this is a built-in controller, our NVM update files might not work for it as this controller would be customized according to ASUS configurations.
Sachin KS
Fikri_Intel
Hi Y_P,
Good day!!
We appreciate you reaching out to us regarding the reported issue. As the product was purchased from one of our OEM partners, we kindly advise you to contact the OEM's support team for assistance. They will be best equipped to provide support and address any concerns related.
We will proceed to close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Fikri O.
