Ethernet Products
4866 Discussions
Intel SR-IOV XL710 VF doesn't work after VM reboot
KPoku
I'm using Ubuntu 16.04.3 LTS with KVM virtualization. Also i'm using
Intel XL710 card with SR-IOV feature.
Here are the outputs:
/lib/modprobe.d$ modinfo i40e
filename:      /lib/modules/4.4.0-96-generic/updates/drivers/net/ethernet/intel/i40e/i40e.ko
version:       2.4.10
license:       GPL
description:   Intel(R) 40-10 Gigabit Ethernet Connection Network Driver
author:        Intel Corporation, <e1000-devel@lists.sourceforge.net>
srcversion:    3977C21019A3C4865FF253A
alias:         pci:v00008086d0000158Bsv*sd*bc*sc*i*
alias:         pci:v00008086d0000158Asv*sd*bc*sc*i*
alias:         pci:v00008086d000037D3sv*sd*bc*sc*i*
alias:         pci:v00008086d000037D2sv*sd*bc*sc*i*
alias:         pci:v00008086d000037D1sv*sd*bc*sc*i*
alias:         pci:v00008086d000037D0sv*sd*bc*sc*i*
alias:         pci:v00008086d000037CFsv*sd*bc*sc*i*
alias:         pci:v00008086d000037CEsv*sd*bc*sc*i*
alias:         pci:v00008086d00001588sv*sd*bc*sc*i*
alias:         pci:v00008086d00001587sv*sd*bc*sc*i*
alias:         pci:v00008086d00001589sv*sd*bc*sc*i*
alias:         pci:v00008086d00001586sv*sd*bc*sc*i*
alias:         pci:v00008086d00001585sv*sd*bc*sc*i*
alias:         pci:v00008086d00001584sv*sd*bc*sc*i*
alias:         pci:v00008086d00001583sv*sd*bc*sc*i*
alias:         pci:v00008086d00001581sv*sd*bc*sc*i*
alias:         pci:v00008086d00001580sv*sd*bc*sc*i*
alias:         pci:v00008086d00001574sv*sd*bc*sc*i*
alias:         pci:v00008086d00001572sv*sd*bc*sc*i*
depends:       ptp,vxlan
vermagic:      4.4.0-96-generic SMP mod_unload modversions
parm:          debug:Debug level (0=none,...,16=all) (int)
 cat /etc/rc.local
#!/bin/sh -e
# rc.local
# By default this script does nothing.
echo 8 > /sys/class/net/enp6s0f1/device/sriov_numvfs
echo 8 > /sys/class/net/enp6s0f0/device/sriov_numvfs
ip link set enp6s0f0 vf 0 mac aa:bb:cc:aa:00:02 vlan 12
ip link set enp6s0f0 vf 1 mac aa:bb:cc:aa:01:02 vlan 32
ip link set enp6s0f0 vf 2 mac aa:ff:ff:aa:00:12 vlan 22
ip link set enp6s0f0 vf 3 mac aa:ff:ff:aa:01:12 vlan 42
ip link set enp6s0f1 vf 0 mac aa:bb:cc:bb:00:02 vlan 52
ip link set enp6s0f1 vf 1 mac aa:bb:cc:bb:01:02 vlan 72
ip link set enp6s0f1 vf 2 mac aa:ff:ff:bb:00:12 vlan 62
ip link set enp6s0f1 vf 3 mac aa:ff:ff:bb:01:12 vlan 82
exit 0
Driver i40e is also blacklisted as suggested in Intel SR-IOV configuration guide.
Everything works ok, but in case i reboot the VM, some of the virtual functions won't work. I need to reboot VM a few times (sometimes i need just one reboot, sometimes like three reboots) and virtual functions start working properly.
I was able only to find this in logs on KVM host (/var/log/kern.log) when VF doesn't work:
Jan 8 09:56:23 ri-cgn-kvm-2 kernel: [15787510.840948] i40e 0000:06:00.0: VF 1 failed opcode 3, retval: -5
Jan 8 09:56:23 ri-cgn-kvm-2 kernel: [15787510.841010] i40e 0000:06:00.0: Invalid message from VF 1, opcode 3, len 4
Jan 8 09:57:08 ri-cgn-kvm-2 kernel: [15787555.936159] i40e 0000:06:00.1: VF 0 failed opcode 10, retval: -5
Jan 8 09:57:08 ri-cgn-kvm-2 kernel: [15787555.936222] i40e 0000:06:00.1: Invalid message from VF 0, opcode 10, len 44
Jan 8 09:57:08 ri-cgn-kvm-2 kernel: [15787555.976198] i40e 0000:06:00.1: VF 0 failed opcode 11, retval: -10
Jan 8 10:05:14 ri-cgn-kvm-2 kernel: [15788042.047074] i40e 0000:06:00.0: VF 0 failed opcode 3, retval: -5
Jan 8 10:05:14 ri-cgn-kvm-2 kernel: [15788042.047138] i40e 0000:06:00.0: Invalid message from VF 0, opcode 3, len 4
Jan 8 10:21:14 ri-cgn-kvm-2 kernel: [15789001.950375] i40e 0000:06:00.0: VF is not trusted, switch the VF to trusted to add more functionality
Jan 8 10:21:14 ri-cgn-kvm-2 kernel: [15789001.951291] i40e 0000:06:00.1: VF is not trusted, switch the VF to trusted to add more functionality
Jan 8 10:21:14 ri-cgn-kvm-2 kernel: [15789001.951300] i40e 0000:06:00.1: VF 1 failed opcode 10, retval: -1
Jan 8 10:21:14 ri-cgn-kvm-2 kernel: [15789001.977115] i40e 0000:06:00.0: VF 1 failed opcode 10, retval: -1
Jan 8 10:37:25 ri-cgn-kvm-2 kernel: [15789972.835652] i40e 0000:06:00.0: VF 1 failed opcode 11, retval: -10
Jan 8 10:37:27 ri-cgn-kvm-2 kernel: [15789975.074702] i40e 0000:06:00.1: VF 1 failed opcode 11, retval: -10
What is causing this issue?
Kresimir
Daniel_D_Intel1
Hello KPoku, Thank you for the information. The kernel is not providing the latest i40e drivers. Please check if updating to the latest i40e drivers resolves the issue. Please check with Cisco if there is a firmware update available for the XL710, as this is an OEM Cisco version. They might also be able to provide the compatibility of drivers with the latest firmware. You can find the latest drivers here: https://downloadcenter.intel.com/download/24411/Intel-Network-Adapter-Driver-for-PCIe-40-Gigabit-Ethernet-Network-Connections-Under-Linux- Let us know if the drivers and firmware update solve this issue. If you have any other questions please inform us. Best regards, Daniel D Intel Customer Support
Daniel_D_Intel1
Hello KPoku, Thank you for posting in Intel Ethernet Communities. Please let us know if this is a retail Intel version of the XL710 adapter or an OEM by providing the markings from the product label. Please include ethtool -i <interface> output to confirm the firmware, and ethtool -k <interface> to provide the features on the NIC. Let us know if you have any other questions. Best regards, Daniel D Intel Customer Support
KPoku
Hi Daniel,
here are outputs of ethtool command:
ethtool -i enp1s0f0
driver: igb
version: 5.3.0-k
firmware-version: 1.63, 0x80000e74, 0.385.8
expansion-rom-version:
bus-info: 0000:01:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
ethtool -k enp1s0f0
Features for enp1s0f0:
rx-checksumming: on
tx-checksumming: on
       tx-checksum-ipv4: on
       tx-checksum-ip-generic: off [fixed]
       tx-checksum-ipv6: on
       tx-checksum-fcoe-crc: off [fixed]
       tx-checksum-sctp: on
scatter-gather: on
       tx-scatter-gather: on
       tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
       tx-tcp-segmentation: on
       tx-tcp-ecn-segmentation: off [fixed]
       tx-tcp6-segmentation: on
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off [fixed]
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: off [fixed]
tx-ipip-segmentation: off [fixed]
tx-sit-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off [fixed]
busy-poll: off [fixed]
hw-tc-offload: off [fixed]
ethtool -i enp1s0f1
driver: igb
version: 5.3.0-k
bus-info: 0000:01:00.1
supports-test: yes
ethtool -k enp1s0f1
Features for enp1s0f1:
rx-checksumming: on
tx-checksumming: on
scatter-gather: on
rx-vlan-offload: on
tx-vlan-offload: on
receive-hashing: on
highdma: on [fixed]
rx-fcs: off [fixed]
rx-all: off
This Intel cards were ordered and provided with Cisco. I'm running CISCO UCS C220M4S server.
Kresimir
Daniel_D_Intel1
Daniel_D_Intel1
Hello KPoku, Please let us know if you are still having any issues after updating to the latest i40e driver and checking if there is a firmware update from Cisco. If you have any other questions please do not hesitate to ask. Best regards, Daniel D Intel Customer Support
Daniel_D_Intel1
Hello KPoku, Please let us know if you still need assistance. If you have any other questions please do not hesitate to ask. Best regards, Daniel D Intel Customer Support Under contract to Intel Corporation
KPoku
Hi Daneil,
i've installed latest drivers, v.2.7.26, one host and didn't experience issue with VF.
I'll be testing for next couple of days to see will issue appear.
Kresimir
Daniel_D_Intel1
Hello KPoku, Thank you for the reply. Please let us know if the issue is still seen in your testing. If you have any other questions please ask. Best regards, Daniel D Intel Customer Support Under contract to Intel Corporation
Daniel_D_Intel1
Hello KPoku, After testing the latest driver for some time are you still getting the expected VF performance? Please let us know if you need additional assistance, or have any questions. Best regards, Daniel D Intel Customer Support Under contract to Intel Corporation
Daniel_D_Intel1
Hello KPoku, Please let us know if you have any questions. If the driver update solved the issue please inform us. Best regards, Daniel D Intel Customer Support Under contract to Intel Corporation
Mike_Intel
Hello KPoku, Please tell us If the driver update solved the issue. Kindly tell us if you have any questions. Best regards, Michael L. Intel Customer Support Under contract to Intel Corporation
KPoku
Hi Michael,
for now i didn't have any issues with latest drivers, so i can say that issue is solved.
Thank you for the assistance.
Kresimir
