Ethernet Products
4528 Discussions
Intel X520 SR-IOV [DMAR:[fault reason 04] Access beyond MGAW]
csaba1
i'm getting TX hang on VF with SR-IOV enable when adding a VF to KVM vm
DESCRIPTION:
i'm using intel X520 RNDc DELL card on poweredge R620,
when adding a VM and assign a new VF to it i'm getting "spoof packet detected" and TX hang floods the screen,
on another SSH session i'm getting multiple lines:
kernel: dmar: DRHD: handling fault status reg 502
kernel: dmar: DMAR:[DMA Write] Request device [01:10.4] fault addr 68c2e85400000
kernel: DMAR:[fault reason 04] Access beyond MGAW
i can run ip link set eth0 vf 0 spoofchk off but seems that only the prints is off but the spoof still occurred and packets are drooped,
SYSTEM-DETAILS
Dell PowerEdge R620
NIC: RNDc 2 ports X520, 2 ports I350
CONNECTION: DIRECT ATTACH
OS: CentOS 6.7
kernel: 2.6.32-573.8.1.el6.x86_64
Linux KVM qemu-kvm-0.12.1.2-2.479.el6_7.2.x86_64
Libvirt libvirt-0.10.2-54.el6_7.2.x86_64
no VLAN is used, only external IP address
OTHER COMMANDS OUTPUT
root@kvmsrv3:~# ethtool -i eth0
driver: ixgbe
version: 4.0.1-k
firmware-version: 0x80000741
bus-info: 0000:01:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
root@kvmsrv3:~# ethtool -S eth0
NIC statistics:
rx_packets: 1198001
tx_packets: 0
rx_bytes: 100415250
tx_bytes: 0
rx_pkts_nic: 15756978
tx_pkts_nic: 17121044
rx_bytes_nic: 3095906789
tx_bytes_nic: 9977985209
lsc_int: 1
tx_busy: 0
non_eop_descs: 0
rx_errors: 294
tx_errors: 0
rx_dropped: 0
tx_dropped: 0
multicast: 3
broadcast: 1197702
rx_no_buffer_count: 0
collisions: 0
rx_over_errors: 0
rx_crc_errors: 0
rx_frame_errors: 0
hw_rsc_aggregated: 0
hw_rsc_flushed: 0
fdir_match: 0
fdir_miss: 0
fdir_overflow: 0
rx_fifo_errors: 0
rx_missed_errors: 0
tx_aborted_errors: 0
tx_carrier_errors: 0
tx_fifo_errors: 0
tx_heartbeat_errors: 0
tx_timeout_count: 0
tx_restart_queue: 0
rx_long_length_errors: 0
rx_short_length_errors: 0
tx_flow_control_xon: 0
rx_flow_control_xon: 0
tx_flow_control_xoff: 0
rx_flow_control_xoff: 0
rx_csum_offload_errors: 0
alloc_rx_page_failed: 0
alloc_rx_buff_failed: 0
rx_no_dma_resources: 476038
.....[ REMOVING 0 LINES ]
rx_queue_0_packets: 786932
rx_queue_0_bytes: 56754214
rx_queue_0_bp_poll_yield: 0
rx_queue_0_bp_misses: 0
rx_queue_0_bp_cleaned: 0
rx_queue_1_packets: 411069
rx_queue_1_bytes: 43661036
rx_queue_1_bp_poll_yield: 0
rx_queue_1_bp_misses: 0
rx_queue_1_bp_cleaned: 0
rx_queue_2_packets: 0
attaching commands outputs that may help
thanks for your help
Chaim
SYeo3
Valued Contributor I
Hi Chaim,
Thank you for contacting Intel Customer Support. We are currently looking into your issue and will update you once we have any findings.
As of the moment, we suggest to also check with Dell* regarding the issue.
Sincerely,
Sandy
