Ethernet Products
5534 Discussions
Intel X540-T2 Windows 10
KKars
Is there any possibility to get an 540-T2 running on Windows 10 1607?
After Driverinstallation i got an Code 10, Driver could not be startet Error.
Thanks for any Help.
Hi KarstenL680,
Thank you for posting your query in Wired Ethernet Communities.
The download package available in the link below should contain driver version = 3.9.58.9102 for Windows 10.
https://downloadcenter.intel.com/download/22283/Intel-Ethernet-Adapters-Connections-CD
regards,
Vince
KKars
Hi Vince,
this drivers i tried but not working, i found out that the card displays a wrong device ID 1512, correct must be device ID 1528.
A0389F33FE04014AD G45270-003 is written on the long Label, hope it helps.
The Device Mangaer shows the following:
PCI\VEN_8086&DEV_1512&SUBSYS_00008086&REV_01
PCI\VEN_8086&DEV_1512&CC_020000
Karsten
Hi Karsten, if loading the latest driver still displays code 10 error, have you tried to install the X540-T2 on another system for further isolation whether it's a hardware problem.
Is the X540-T2 works fine on non-Windows 10 system?
regards,
Vince
Hi Karsten, I'd like to check if you still need assistance regarding X540-T2.
regards,
Vince
KKars
Hi Vince,
i have only testet in one Win 10 System, but the wrong Device IDs makes me nervous.
I can check in a different system next week.
Karsten
Hi Karsten,
Just want to check if you were able to try it out in different system.
Vince
