I've 2 rental servers both of them have AMD EPYC 7413 CPU and installed Windows Server 2022(second time fresh install).
On the first server there is not one single problem for months, the newest server always have the disconnecting problem randomly and i'm out of ideas what to do anymore. I've updated drivers, installed the same driver version with the first server and etc but somehow randomly disconnecting and connecting back with couple of minutes after the disconnect. Also, i've updated the firmware but still no luck.
This is the second time installing fresh. Also tried with linux and there is not one single problem on linux, so the company i rented wants me to try on their linux and as they say i tried and they also made some checks, its not a hardware problem as they say. So i cannot demand a replacement. The problem occurs on windows only.
What should i do ?
Hello theDeveloper,
For us to further check the issue, please provide the following details.
- Are you using a PCIe X550-T2 or is it embedded on the board?
- If you are using a PCIe X550-T2, please send photos on the unit on both sides focusing on the markings for us to validate if the unit is an OEM unit or not.
- Please share the link of your latest driver.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
Thanks for your reply,
1) It's embedded on board. (https://www.tyan.com/Motherboards_S8030_S8030GM4NE-2T)
2) n/a
3)Right now its from the Windows Update, but before doing a fresh install again, i've installed this one and its also has the same problem. => https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html?
Hello theDeveloper,
Thank you for the quick reply. Upon further checking retail Intel X550-T2 should support Windows 2022. Please refer to this link:
https://www.intel.com/content/www/us/en/support/articles/000025890/ethernet-products.html
However, your Intel X550-T2 is onboard and onboard network cards are considered OEM units. For issues like this, we advise our customer's to contact OEM manufacturer which is Tyan to check compatibility and they may have custom driver, software and firmware to enable all the features of your network card.
Upon checking, I also found out that Tyan have available LAN drivers but it is for Windows server 2016 / Windows Server 2019 only. You need to check with Tyan if the board supports Windows 2022.
https://www.tyan.com/Motherboards=S8030=S8030GM4NE-2T=downloads=EN
Michael L.
Hello theDeveloper,
I hope you're having a wonderful day. I am just sending a soft follow up hoping that you already tried to contact the OEM Tyan since they are the best team who can assist you regarding this concern.
Michael L.
I've tried to contact them but i didnt still get a response yet, and in the meantime the problem still persists.
I've installed chipset drivers on their web site etc but didnt fixed the problem.
Also, search thru the intel forums some people said disabling power saving feature may fix but it didnt.
Hello theDeveloper,
I am really sorry to hear that and I hope you will get a reply from Tyan soon. As much as we want to further assist you, our support for OEM unit is very limited since we don't know the alterations that they made on the unit.
Michael L.
I'm still thinking its a driver problem,
I've tried something and its kinda worked, i've tried a constant pinging via ping -t ip_adress and while this ping working the disconnection is never occurred. Why is that?
Hello theDeveloper,
Thank you for the update and I am glad that it is seems working now. Regarding your question, this is the problem with OEM units. We don't know the alterations that the OEM manufacturer made on the unit. Only the OEM manufacturer knows the testing that they made before releasing their products. That is why it is still best to coordinate the issue moving forward with Tyan.
Michael L.
Hello theDeveloper,
I hope you're having a wonderful day. I am just sending a soft follow up hoping that you tried contacting Tyan for further assistance regarding the issue. We will wait for your reply.
Michael L.
Thank you for your reply Mike,
But the company is not replying back e-mails or phone calls. I know you are trying to help but i'm out of ideas to try something and issue is still there.
Hello theDeveloper,
I am sorry to hear that. Kindly try again and wait for their update since they are the best team who can assist you regarding this inquiry.
Michael L.
Hello theDeveloper,
I hope you're having a wonderful day. I am just checking if you are now talking with Tyan for further assistance.
Michael L.
Hello theDeveloper,
I hope this message finds you well. I am just sending another message hoping that Tyan already responded to your message since they are the best team who can assist you. Since we have not heard back from you, I need to close this inquiry.
Thank you and stay safe.
Michael L.
Thanks for your reply Mike,
After waiting too long finally Tyan responded with a firmware, i'll install the new firmware and test it out. Hopefully it will fix everything.
