Ethernet Products
5820 Discussions
Intel X550-T2 NIC connect to 2.5Gb switch link rate show 1000 on Ubuntu 20.04
Jacy
We install X550-T2 card on ubuntu 20.04 system and upgrade the ixgbe driver to 5.12.5,
When we connect to 2.5Gb switch, the link rate always show 1G, How to up the link speed to 2.5Gb,
root@rd2-System-Product-Name:# lspci -v |grep Ethernet -A 1
02:00.0 Ethernet controller: Intel Corporation Ethernet Controller 10G X550T (rev 01)
Subsystem: Intel Corporation Ethernet Converged Network Adapter X550-T2
Flags: bus master, fast devsel, latency 0, IRQ 18
02:00.1 Ethernet controller: Intel Corporation Ethernet Controller 10G X550T (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 17
root@rd2-System-Product-Name:/home/rd2/Desktop/gateway# ethtool -i enp2s0f1
driver: ixgbe
version: 5.12.5
firmware-version: 0x8000156e, 1.2926.0
expansion-rom-version:
bus-info: 0000:02:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
8: enp2s0f1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether a0:36:9f:20:69:de brd ff:ff:ff:ff:ff:ff
root@rd2-System-Product-Name:~# ethtool enp2s0f1
Settings for enp2s0f1:
Supported ports: [ TP ]
Supported link modes: 100baseT/Full
1000baseT/Full
10000baseT/Full
2500baseT/Full
5000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 100baseT/Full
1000baseT/Full
10000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: 100Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
Mike_Intel
Hello Jacy,
For us to further check and investigate the issue, please provide the following details.
  1. Can you provide a screenshot of the issue while testing the speed?
  2. Please provide photos of the card on both sides focusing on the markings.
  3. What is the brand and model of your board or system?
  4. Can you share the link of your latest driver?
  5. What are the troubleshooting steps that you tried so far?
  6. Please help generate the SSU logs of the system. Please download the utility below:
https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-operating-system.html?wapkw=ssu
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Jacy
Hello Michael,
  1. Can you provide a screenshot of the issue while testing the speed?Screenshot from 2021-09-06 13-35-16.pngScreenshot from 2021-09-06 13-41-11.png
                  Motherboard: ASUS Z590A
                  CPU: i7 10700K
                  Ethernet : Intel I225V, X550-T, I350
           https://www.intel.com.tw/content/www/tw/zh/download/14302/intel-network-adapter-driver-for-pcie-intel-10-gigabit-ethernet-network-connections-under-linux.html
           a. We try X550-T2 connect to I225 interface, the link rate always keep on 1Gb.
           b. X550-T2 port 1 connect to port 2, the link rate will up to 10Gb.
          SSU Log:
# SSU Scan Information
Scan Info:
Version:"1.0.0.0"
Scan Date:"2021/09/06"
Scan Time:"13:36:04"
## Scanned Hardware
Computer:
BaseBoard Manufacturer:"ASUSTeK COMPUTER INC."
Bios Mode:"UEFI"
Bios Version/Date:"0605,03/11/2021"
CD or DVD:"Not Available"
Platform Role:"Linux rd2-System-Product-Name 5.11.0-27-generic #29~20.04.1-Ubuntu SMP Wed Aug 11 15:58:17 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux"
Processor:"Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz"
Serial Number:"System Serial Number"
SMBIOS Version:"3.3.0"
Sound Cards:"HDA-Intel - HDA Intel PCH"
Sound Cards:"HDA Intel PCH at 0x6002110000 irq 208"
System Manufacturer:"ASUS"
System Model:"System Product Name"
System Type:"x64-based PC"
- Display
- "Intel Corporation Device 9bc5 (rev 05) (prog-if 00 [VGA controller])"
Adapter RAM:"size=256M"
Capabilities:"[40] Vendor Specific Information: Len=0c <?>"
Capabilities:"[70] Express Root Complex Integrated Endpoint, MSI 00"
Capabilities:"[ac] MSI: Enable+ Count=1/1 Maskable- 64bit-"
Capabilities:"[d0] Power Management version 2"
Capabilities:"[100] Process Address Space ID (PASID)"
Capabilities:"[200] Address Translation Service (ATS)"
Capabilities:"[300] Page Request Interface (PRI)"
Caption:"Intel Corporation Device 9bc5 (rev 05) (prog-if 00 [VGA controller])"
Device ID:"1043:8694"
Driver:"i915"
Driver Path:"/lib/modules/5.11.0-27-generic/kernel/drivers/gpu/drm/i915/i915.ko"
Driver Provider:"Intel Corporation"
Driver Provider:"Tungsten Graphics, Inc."
Driver Version:""
Flags:"bus master, fast devsel, latency 0, IRQ 207"
I/O Ports:"I/O ports at 4000 [size=64]"
Manufacturer:"Intel Corporation [8086]"
Power Management Capabilities:"Power Management version 2"
Refresh Rate - Current:"60.02 75.02 "
Resolution:"1280x1024 75.02 "
- Memory
Physical Memory (Available):"13851 MB"
Physical Memory (Installed):"15780 MB"
Physical Memory (Total):"17828 MB"
- "Controller0-ChannelA"
Capacity:"8192 MB"
Configured Clock Speed:"Not Available"
Configured Voltage:"1.2 V"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"First Position"
Locator:"Controller0-ChannelA"
Manufacturer:"Kingston"
Maximum Voltage:"1.2 V"
Minimum Voltage:"1.2 V"
Part Number:"905702-400.A00G"
Serial Number:"D79841F2"
Type:"Synchronous"
- "Controller0-ChannelB"
Capacity:"8192 MB"
Form Factor:"DIMM"
Locator:"Controller0-ChannelB"
Serial Number:"B89846CD"
Type:"Synchronous"
- Motherboard
Product:"PRIME Z590-A"
Serial Number:"210484560301435"
Version:"Rev 1.xx"
- Networking
- "Intel Corporation Ethernet Controller 10G X550T (rev 01)"
Supports auto-negotiation:"Yes"
Advertised auto-negotiation:"Yes"
Auto-negotiation:"on"
Availability:"enp2s0f0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500"
Capabilities:"[40] Power Management version 3"
Capabilities:"[50] MSI: Enable- Count=1/1 Maskable+ 64bit+"
Capabilities:"[70] MSI-X: Enable+ Count=64 Masked-"
Capabilities:"[a0] Express Endpoint, MSI 00"
Capabilities:"[100] Advanced Error Reporting"
Capabilities:"[140] Device Serial Number 9f-c3-b5-ff-ff-98-00-00"
Capabilities:"[150] Alternative Routing-ID Interpretation (ARI)"
Capabilities:"[160] Single Root I/O Virtualization (SR-IOV)"
Capabilities:"[1a0] Transaction Processing Hints"
Capabilities:"[1b0] Access Control Services"
Capabilities:"[1c0] Latency Tolerance Reporting"
Capabilities:"[1d0] Secondary PCI Express"
Caption:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"ixgbe"
Driver Path:"/lib/modules/5.11.0-27-generic/updates/drivers/net/ethernet/intel/ixgbe/ixgbe.ko"
Driver Provider:"Intel Corporation, <linux.nics@intel.com>"
Driver Version:""
Duplex:"Full"
Firmware Version:"0x8000156e, 1.2926.0"
Interface:"enp2s0f0"
I/O Ports:"Not Available"
IP Address:"Not Available"
IP Subnet:"Not Available"
MAC Address:"a0:36:9f:20:69:dc"
Manufacturer:"Intel Corporation"
Net Connection ID:"Not Available"
Port:"Twisted Pair"
Power Management:"Supports Wake-on: d"
Power Management:"Wake-on: d"
Speed:"1000Mb/s"
Supported link modes:"100baseT/Full, 1000baseT/Full, 10000baseT/Full"
Advertised link modes:"100baseT/Full, 1000baseT/Full, 10000baseT/Full"
Partner advertised link modes:"Not Available"
Availability:"enp2s0f1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500"
DHCP Enabled:"Yes"
Driver:"ixgbe"
Driver Version:""
Duplex:"Full"
Interface:"enp2s0f1"
MAC Address:"a0:36:9f:20:69:de"
Port:"Twisted Pair"
Speed:"1000Mb/s"
- "Intel Corporation I350 Gigabit Network Connection (rev 01)"
Availability:"enp3s0f0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500"
Capabilities:"[70] MSI-X: Enable+ Count=10 Masked-"
Capabilities:"[140] Device Serial Number a0-36-9f-ff-ff-aa-92-98"
Capabilities:"[1d0] Access Control Services"
Default IP Gateway:"192.168.233.1"
DHCP Enabled:"Yes"
Driver:"igb"
Driver Path:"/lib/modules/5.11.0-27-generic/kernel/drivers/net/ethernet/intel/igb/igb.ko"
Driver Provider:"Intel Corporation, <e1000-devel@lists.sourceforge.net>"
Driver Version:""
Duplex:"Full"
Firmware Version:"0.93, 0x800005fd"
Interface:"enp3s0f0"
IP Address:"192.168.233.24"
IP Subnet:"255.255.255.0"
MAC Address:"a0:36:9f:aa:92:98"
Port:"Twisted Pair"
Power Management:"Supports Wake-on: pumbg"
Power Management:"Wake-on: g"
Speed:"1000Mb/s"
Supported link modes:"10baseT/Half 10baseT/Full, 100baseT/Half 100baseT/Full, 1000baseT/Full"
Advertised link modes:"10baseT/Half 10baseT/Full, 100baseT/Half 100baseT/Full, 1000baseT/Full"
Availability:"enp3s0f1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500"
DHCP Enabled:"Yes"
Driver:"igb"
Driver Version:""
Duplex:"Unknown! (255)"
Interface:"enp3s0f1"
MAC Address:"a0:36:9f:aa:92:99"
Port:"Twisted Pair"
Speed:"Unknown!"
Availability:"enp3s0f2: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500"
DHCP Enabled:"Yes"
Driver:"igb"
Driver Version:""
Interface:"enp3s0f2"
MAC Address:"a0:36:9f:aa:92:9a"
Port:"Twisted Pair"
Speed:"Unknown!"
Availability:"enp3s0f3: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500"
DHCP Enabled:"Yes"
Driver:"igb"
Driver Version:""
Interface:"enp3s0f3"
MAC Address:"a0:36:9f:aa:92:9b"
Port:"Twisted Pair"
Speed:"Unknown!"
- "Intel Corporation Device 15f3 (rev 03)"
Availability:"enp5s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500"
Capabilities:"[70] MSI-X: Enable+ Count=5 Masked-"
Capabilities:"[140] Device Serial Number 7c-10-c9-ff-ff-22-41-2d"
Capabilities:"[1f0] Precision Time Measurement"
Capabilities:"[1e0] L1 PM Substates"
DHCP Enabled:"Yes"
Driver:"igc"
Driver Path:"/lib/modules/5.11.0-27-generic/kernel/drivers/net/ethernet/intel/igc/igc.ko"
Driver Version:""
Firmware Version:""
Interface:"enp5s0"
MAC Address:"7c:10:c9:22:41:2d"
Port:"Twisted Pair"
Speed:"Unknown!"
- Operating System
Boot Device:"/dev/sda6"
Last Reset:"up 1:50, 1 user, load average: 0.67, 0.40, 0.18"
Locale:"en_US"
OS Manufacturer:"Ubuntu 20.04.3 LTS \n \l"
OS Name:"Ubuntu 20.04.3 LTS \n \l"
Page File:"/swapfile"
Page File Space (Available):"2097148"
Page File Space (Used):"0"
Physical Memory (Available):"13848 MB"
Version:"5.11.0-27-generic GNU/Linux"
Virtual Memory (Available):"2097148"
Virtual Memory (Total):"16159420"
- Processor
- "Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz"
Architecture:"x86_64"
Available:"Offline"
Byte Order:"Little Endian"
Cache Size:"16384 KB"
Caption:"Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz"
- Characteristics
64-bit capable
Enhanced Virtualization
Execute Protection
Hardware Thread
Multi-Core
Power/Performance Control
CPU Speed (Minimum):"3212.622"
CPU Speed (Maximum):"12000 MHz"
Current Voltage:"1.0 V"
External Clock:"100 MHz"
Family:"Core i7"
- Flags
"ACPI (ACPI supported)"
"APIC (On-chip APIC hardware supported)"
"CLFSH (CLFLUSH instruction supported)"
"CMOV (Conditional move instruction supported)"
"CX8 (CMPXCHG8 instruction supported)"
"DE (Debugging extension)"
"DS (Debug store)"
"FPU (Floating-point unit on-chip)"
"FXSR (FXSAVE and FXSTOR instructions supported)"
"HTT (Multi-threading)"
"MCA (Machine check architecture)"
"MCE (Machine check exception)"
"MMX (MMX technology supported)"
"MSR (Model specific registers)"
"MTRR (Memory type range registers)"
"PAE (Physical address extension)"
"PAT (Page attribute table)"
"PBE (Pending break enabled)"
"PGE (Page global enable)"
"PSE-36 (36-bit page size extension)"
"PSE (Page size extension)"
"SEP (Fast system call)"
"SSE2 (Streaming SIMD extensions 2)"
"SSE (Streaming SIMD extensions)"
"SS (Self-snoop)"
"TM (Thermal monitor supported)"
"TSC (Time stamp counter)"
"VME (Virtual mode extension)"
ID:"55 06 0A 00 FF FB EB BF"
Level 1 Cache:"256 KiB
fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single ssbd ibrs ibpb stibp ibrs_enhanced fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp pku ospke md_clear flush_l1d arch_capabilities"
Level 2 Cache:"2 MiB"
Level 3 Cache:"16 MiB"
Load:"load average: 0.67, 0.40, 0.18"
Manufacturer:"Intel(R) Corporation"
Model:"165"
Name:"Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz"
Number of Cores:"8"
Number of Cores - Enabled:"8"
Part Number:"To Be Filled By O.E.M."
Socket Designation:"LGA1200"
Status:"Populated, Enabled"
Version:"Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz"
Voltage:"1.0 V"
Virtualization:"Not Available"
- Storage
- "WDC_WD10EZEX-00WN4A0"
Capabilities:"LBA, IORDY(can be disabled)"
Capabilities:"Queue depth: 32"
Capabilities:"Standby timer values: spec'd by Standard, with device specific minimum"
Capabilities:"R/W multiple sector transfer: Max = 16 Current = 16"
Capabilities:"DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6 "
Capabilities:"Cycle time: min=120ns recommended=120ns"
Capabilities:"PIO: pio0 pio1 pio2 pio3 pio4 "
Capabilities:"Cycle time: no flow control=120ns IORDY flow control=120ns"
Caption:"/dev/sda"
Cylinders - Total:"16383"
Description:"ATA device, with non-removable media"
Firmware:"01.01A01"
Heads - Total:"16"
Index:"Not Available"
Interface Type:"ATA"
Manufacturer:"WDC"
Model:"WDC WD10EZEX-00WN4A0"
Partitions:"Not Available"
Sectors - Per Track:"63"
Serial Number:"WD-WCC6Y4VEA73Z"
Size:"1024*1024: 953869 MBytes"
Size:"1000*1000: 1000204 MBytes (1000 GB)"
Size - Available:"Filesystem 1K-blocks Used Available Use% Mounted on"
Size - Available:"/dev/sda6 518445096 14924764 477115060 4% /"
Size - Available:"/dev/sda2 98304 30941 67363 32% /boot/efi"
SMART Attributes:"* SMART Command Transport (SCT) feature set"
SMART Attributes:"* SMART error logging"
SMART Attributes:"* SMART feature set"
SMART Attributes:"* SMART self-test"
- SMART
001 Raw_Read_Error_Rate :200:"051"
003 Spin_Up_Time :189:"021"
004 Start_Stop_Count :100:"000"
005 Reallocated_Sector_Ct :200:"140"
007 Seek_Error_Rate :200:"000"
009 Power_On_Hours :100:"000"
010 Spin_Retry_Count :100:"000"
011 Calibration_Retry_Count :100:"000"
012 Power_Cycle_Count :100:"000"
192 Power-Off_Retract_Count :200:"000"
193 Load_Cycle_Count :200:"000"
194 Temperature_Celsius :102:"000"
196 Reallocated_Event_Count :200:"000"
197 Current_Pending_Sector :200:"000"
198 Offline_Uncorrectable :100:"000"
199 UDMA_CRC_Error_Count :200:"000"
200 Multi_Zone_Error_Rate :100:"000"
Mike_Intel
Hello Jacy,
Thank you so much for the update. Upon checking, your card can only support up to Ubuntu 18.x, please open the link below for reference:
https://www.intel.com/content/www/us/en/support/articles/000025890/ethernet-products.html
Regarding the driver, can you try the link below:
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html?wapkw=X550-T2
Michael L.
Jacy
Hello Michael,
   OK, Got it,
   I have install Ubuntu 18.04 test again, the X550-T2 link rate can use 2.5Gb,
Mike_Intel
Hello Jacy,
Thank you so much for the update and I am glad that you were able to fix the issue. Since the speed of your connection is now fixed, I need to close this inquiry.
If you need assistance again in the future, please post a new question.
Thank you and stay safe.
Michael L.
