Ethernet Products
5500 Discussions
Intel X550-T2: no ASPM support listed
Grobhack
Hello my intel X550-T2 card lists no ASPM support, but i intentinaly bought it because i thought it had what could be the problem? Here some logs:
01:00.0 Ethernet controller: Intel Corporation Ethernet Controller X550 (rev 01)
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM not supported
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
01:00.1 Ethernet controller: Intel Corporation Ethernet Controller X550 (rev 01)
nvmupdate64e -v
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.40.5.5
Copyright(C) 2013 - 2023 Intel Corporation.
Version:
QV SDK - 2.40.05.03
igb - unknown
ixgbe - unknown
i40e - unknown
ice - unknown
nvmupdate64e
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [|.........]
Num Description Ver.(hex) DevId S:B Status
01) Intel(R) Ethernet 10G 2P X550-t 3.21(3.15) 1563 00:001 Update not
Adapter available
Tool execution completed with the following status: Device not found.
Press any key to exit.
Sazirah
*apologies
For the steps of configuring ASPM in BIOS, please follow below (i have made some changes)
Access the BIOS> Go to Advanced and then Integrated IO configuration.
Use down arrow keys to select PCIe Misc. Configuration Under Integrated IO configuration.
Press enter key to view the options in PCIe ASPM Support (Global).
Select Enable and press enter to select the option.
Press F10 to save and Exit.
Sazirah
Hi Grobhack,
Thank you for contacting Intel Ethernet Communities.
Please give us some time to check on this and we will get back to you with any update.
Sazzy_Intel
Sazirah
Hi Grobhack,
Regarding your issue, can you check the status of ASPM in BIOS? Below is the steps:
Select Disabled and press enter to select the option.
Also, you can try steps in this link : https://www.intel.com/content/www/us/en/support/articles/000092564/graphics.html
Please let us know the outcome.
Additionally, please share the ssu logs for us to investigate further.
Sazzy_Intel
Sazirah
*apologies
Grobhack
Thanks, for the ideas and I will try them an send the logs, but it won’t be before the weekend because I’m currently not at home.
Sazirah
Hi Grobhack,
Thank you for your reply.
Sure, let us know when you have try the steps provided. If that's the case, I will wait for your update and will follow up again next week for any update.
Sazzy_Intel
Grobhack
It seems to be working now after changing the bios setting
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <2us, L1 <16us
LnkCtl: ASPM L1 Enabled; RCB 64 bytes, Disabled- CommClk+
I have attached some pictures of the bios settings.
I am still only reaching package c-state c2 but thats probably nothing to do with the Ethernet Controler
Solution: the thing that fixed it for me was a reboot and reseting the bios and setting the the required settings again, they were set before, but setting them again fixed it for me.
I also have run powertop --auto-tune but i'm not sure if it's part of the solution, also i have a kernel parameter set for pci_aspm.policy=powersave but same as for powertop i'm not sure if this is part of the solution, just saying it to show the complete picture.
(Virus scan in progress ...)
ManoranjanDas
Hello Linus,
Greetings to the day!
Thank you for providing the information. We truly value your cooperation and patience throughout this process.
Could you kindly confirm if there are any additional issues that need to be addressed? Additionally, may I kindly ask for your confirmation to proceed with closing this case?
Thank you for choosing Intel products and services.
Manoranjan Das
Sazirah
Hi Grobhack,
Good day.
This is regarding your enquiry above.
Since we have not seen an update, we will be closing this forum case from our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
