Ethernet Products
5821 Discussions
Intel X550T2 and Windows 10 1803 17133.1 x64 PRO -> No connection
MM69
the Intel X550T2 does not work with Windows 10 1803 17133.1 x64 PRO (RTM).
The NIC gets no connection to the intenet and the local network. I tested this with the driver 23.1.
When will apear new drivers for Windows 10 1803?
Hallo,
die Intel X550T2 funktioniert nicht unter Windows 10 1803 17133.1 x64 Pro, welches als die RTM gilt.
Die Netzwerkkarte kann keine Verbindung zum Internet oder zum lokalen Netz aufbauen. Getestet wurde das mit Treiber in der Version 23.1
Wann sind für Windows 10 1803 neue Treiber erhältlich?
MfG MM69
Hi Madmarc69,
Thank you for posting in Wired Communities. I will further check for you about the driver release. Just to double check does this issue occurred only if you used Windows 10 (1803)?
Sharon T
MM69
It only occures in Windows 10 1803.
1709 works fine.
Hi Madmarc69,
Thank you for the clarification. We don't have the timeline when the updated driver for Windows 10 (1803) will be available,you can try check for the driver sometimes in the end of April or early May. Please feel free to visit our http://downloadcenter.intel.com from time to time for the updates. Hope this clarified.
Sharon T
Hi Madmarc69,
Just want to double check any further assistance needed? Please feel free to update me.
Sharon T
MM69
i am waiting for a wo@rking driver for Windows 10 1803 x64 pro. Any news about this?
MM69
Hi Madmarc69,
Thank you for the reply. The latest PROSet version (containing the driver) is still 23.1. I will update you when there is new driver available.
Sharon T
Hi Madmarc69,
Please be informed the new driver release should be available within the next couple of weeks. Thank you for your patience on this matter.
Sharon T
Hi Madmarc69,
Here is a recent update about the Windows 10 RS4 driver for Intel NIC, please refer to the May 25th post of Intel Ethernet at https://communities.intel.com/thread/124133?start=30&tstart=0 https://communities.intel.com/thread/124133?start=30&tstart=0 for our latest update. Thanks for your patience on this matter.
Sharon T
MM69
The new driver 23.2 works for my X550-T2 an Windows 10 1803.
Thank you.
Hi Madmarc69,
Thank you for the update and glad to know the new driver 23.2 works for you.
Sharon T
