Ethernet Products
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4735 Discussions
Intel X550T2 and Windows 10 x64 PRO 1809 teaming broken again
MM69
teaming is broken again with Windows 10 x64 PRO 1809. Every half year the same problem...
When will be a new driver for 1809 relasesed?
MM69
Hi MM69,
Thank you for posting in Wired Ethernet Communities.
We'd like to request for additional information regarding your issue, please refer to the items below:
1. Error message or specific issue with the Teaming
2. Did you remove the Teaming configuration prior to upgrade from 1803 to 1809?
3. Is the Teaming configuration still exist after the upgrade from 1803 to 1809?
4. Were you running any network traffic over the Team while performing the upgrade?
5. Kindly provide your system information. You may use our https://downloadcenter.intel.com/download/25293/ Intel® SSU and attach the output text file in the thread.
Vince T.
Intel Customer Support
Hi MM69,
We'd like to follow-up the requested information. Thanks.
Vince T.
MM69
1. Both team members are inactive
2. No
3. Yes, but inactive
4. I installed from USB
5. Not possible. I am back to 1803
I deleted the team and build it again, I installed the v23.2 Driver again. Nothing helped.
Best Regards
MM69
Hi MM69,
Thanks for sharing the information. We'll look into this concern and update the thread as soon as possible.
Vince T.
Hi MM69,
After further checking, there's still no timeline on the release of the updated PROSet. Please monitor this https://downloadcenter.intel.com/download/25016/Ethernet-Intel-Network-Adapter-Driver-for-Windows-10 link for new release.
Vince T.
Hi MM69,
Team configuration for Microsoft Windows*10 1809 (RS5) will be available in SW Release 23.5. This SW is expected in November of 2018.
For complete details, please refer to this /community/tech/wired/blog/2018/10/23/team-and-vlan-configuration-for-microsoft-windows-10-1809-rs5-and-microsoft-windows-server-2019-will-be-available-in-sw-release-234 blog post.
Vince T.
MM69
With driver v23.5 teaming is working.
