We have released a purchase order for Intel X520 10G ethernet adapter.
Now the vendor is telling that X520 is end of life and the replacement is X710-DA2.
I want the 10G network adapter to be used with Z820 Workstation(Windows 7 64 bit OS) from HP.
HP has suggested drivers for Z820.
As per your website:
X710-DA2 is not supported in windows 7 64bit OS and windows 10 64 bit OS.
Can you please verify?
I have some C++/C# code for proving the 1G UDP protocol based data transfer between 2 PCs.
Ref: https://docs.microsoft.com/en-us/dotnet/api/system.net.sockets.udpclient?view=netcore-3.1
Will the same code work for X710-DA2?
Do you have sample code (C++/C#) to prove the UDP protocol based data transfer between two ports in the X710.
I have a loopback cable to connect the two ports.
Vinod
Hello vinodv,
Thank you for posting in Intel Ethernet Communities and we sincerely apologize for the delay on our response. We are now done with the system upgrade and we will be glad to continue assisting you.
Please allow 1-3 business days for us to check on your request. Rest assured that we will provide an update once there is any findings.
Hoping for your kind patience.
Crisselle C
Intel® Customer Support
Hello vinodv,
Good day!
Can you please confirm what is the exact model of X520 you require as the Intel® Ethernet Converged Network Adapter X520-QDA1 and Intel® Ethernet Converged Network Adapter X520-T2 are the only EOL adapters from X520 series?
Please refer to this link for the list of Intel® Ethernet Server Adapter X520 Series. If the status is 'Launched', this means that the adapter is still being manufactured by Intel. If 'Discontinued', meaning that Intel has stop manufacturing the specific product.
Let us know if you have additional questions and clarifications.
We look forward to your reply.
Should there be no response, we will reach out after 3 business days.
Crisselle C
Hello vinodv,
How are you today?
Please provide the information we requested for us to proceed checking your query. If you have any additional questions, please do not hesitate to let us know.
Awaiting to your response.
We will reach out after 3 business days in case we don't hear from you.
Crisselle C
Hello vinodv,
How are you today?
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Crisselle C
