Hello!
We are looking for the Intel Network Adapters for our project (high-speed packet processing using the DPDK framework).
Intel X710-DA2 NICs satisfy our requirements, but we have a question regarding their connection possibilities.
QUESTION:
We would like to connect Intel X710-DA2 NIC (SFP+) to a switch with XFP 10G interfaces.
There is a number of XFP-SFP+ adapters (for example, HP 10G X244 XFP to SFP+ 3m Direct Attach Copper Cable), but according to the "Intel Ethernet Adapters and Devices User Guide", only SFP+ modules made by Intel are supported. It looks like there is no XFP-SFP+ adapter made by Intel.
Is there any way to link the Intel X710-DA2 NIC to the XFP interface of the switch?
What can you recommend in this case?
Andrew
You can use Twinax Copper Cables as a cost effective option. however we just bout 8 of these cards and they keep resetting their interfaces.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c... http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c...
