We added a new node to our cluster and we've got 2 of the Intel X710-T4 cards in the server. Both of our SANs are currently only 1Gb (we have a Tegile T3100 and a Lenovo px12-450r). Whenever i try to setup SAN connections using one of the ports on these NICs it causes all sorts of issues. We have CSVs go offline and report being corrupted and unreadable, we've lost VM configs and VMs stop booting from any volumes that are being hosted by this node (2016 Hyper V cluster). The odd part is that this same node was working fine in our 2012 cluster before we updated/migrated into 2016. I have the latest drivers for the adapter. Here are some things that have happened:
- When I initially brought the node into the cluster I configured all 3 connections to the SANs using the X710-T4 (2 for the tegile for each independent switch/controller and 1 for the lenovo which is directly connected). Right off the bat each time this node took ownership of either volume on the Lenovo the VMs that were on that volume would no longer boot. They would give different weird boot errors and eventually it would even hard lock the Lenovo SAN itself and I'd have to hard boot it. I moved that connection down to the onboard broadcom 1Gb NIC and that solved those issues. The tegile was still connected via the X710-T4 and while it continued to operate, some odd things happened here as well. Sometimes the list of connected iSCSI devices would just be blank on that node even though it was still operating. In the latest case the node took ownership of a LUN from the Tegile and immediately all the VMs on that LUN stopped working and the CSV reported as corrupt and unreadable. I moved the CSV to another node and after a while it finally started working again. Problem is this node insists on taking ownership of storage nodes and there doesnt appear to be a way to stop it (cant set node preferences on CSVs). So right now I'm scared to unpause this node and am contemplating just moving the Tegile connections into the broadcom as well and hopefully avoid all the hassle.... but when we eventually do upgrade our SAN and go 10Gb I dont want to run into this issue again.
I realize this is probably incredibly hard to decipher... at this point I'm just looking for suggestions. Is it one of the adapter properties? The adapters that connect to the SANs have all protocols except IPv4 unchecked, they have jumbo frames set to 9014 and they are set to not allow the OS to turn them off (power saving thing). Aside from that they are basically at default settings. I think I could probably disable SRV-IO on these adapters but is that causing my issue (I doubt it). Let me know what you think!
- « Previous
- 1
- 2
- Next »
Hello KeithW19,
If you have any questions please let us know.
Daniel D.
Intel Customer Support
Unfortunately the update did not work as it did not detect any cards in my system. I'm attaching screenshots of the update window and of device manager
Hello KeithW19,
Thank you for the reply. Please provide the product label markings on the adapter as shown in the following https://www.intel.com/content/www/us/en/support/articles/000007060/network-and-i-o/ethernet-products.html link. This will help us understand why the NVM update is not being accepted. If you have any questions please let us know.
Daniel D
Hello KeithW19,
Checking back to see if you were able to get the markings from the adapter. We will need this to verify the NVM update being used is correct. If you have any trouble locating the markings please let us know.
Daniel
Hello KeithW19,
Please let us know if you are able to provide the adapter markings. If you have any questions please do not hesitate to ask.
Daniel
Hello KeithW19 and Intel,
Have you solved the issue at this point? I am having the same or similar issue with my X710-DA4 cards that I recently installed in our Server 2016 Hyper-V cluster environment. I have the same issue with iSCSI luns on these cards. My situations is worse however as my control panel and driver utilties become unresponsive making any changes to the interfaces nearly impossible. My only temporary solution has been to use the basic universal driver and not the intended driver. My issue is consistent between both of my Cisco UCS servers. I have not updated firmware on the cards but I have tried different driver versions which result the same on my end.
- « Previous
- 1
- 2
- Next »
