Ethernet Products
5777 Discussions
Intel X710-bm2 can't disable auto-negotiation
JJ99
Test Setup #1: Dell R740 Server with Intel X710 fiber card<--Fiber cable--> COTS Media Converter 1 <--RJ45--> COTS Media Converter 2 <--Fiber cable--> Marvell eval board    -----> That worked and linked.
Test Setup #2: Dell R740 with Intel X710 fiber card <--Fiber cable--> Marvell eval board    -----> That not worked and not linked.
Our goal is making test setup #2 able to work and link. We believe that if we want test setup #2 work, we have to disable the auto-negotiation. However, we can't disable the auto negotiation in NIC configuration. Which means X710 network card didn't disable auto-negotiation when choosing a specific speed and duplex setting.
we are wondering how can we disable the auto-negotiation.
Dell R740 Server: Windows Server 2012 R2
Intel X710 card driver: 1.16.202.0
Faez_Intel
Hi JJ99.
For us to check your query, please provide the following information.
  1. Operating System used
  2. Driver version of Intel(R) Ethernet Converged Network Adapter X710-BM2?
From the screenshot attached, I can see that you are trying to change auto nego from OEM page. Can you confirm if you are able to do perform the change using the Device Manager or from the OS to configure the Auto Nego?
Faez_Intel
Faez_Intel
Good day. This is a follow up on this thread. Please kindly let us know if you need any further assistance for this thread.
Do let us know if you have any other questions.
Faez_intel
Hayat
Hello JJ99,
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply here to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank You.
Hayat
Intel® Customer Support
Hayat
Hello JJ99,
Since there are no further replies on the thread, we will proceed to close the thread
Kindly open a new thread if you have further questions.
Thank You.
Hayat
